Hi,
I've been having issues while creating landscape areas in Vectorworks 2021. The areas created all have the same settings (species, density, unstyled Landscape Area, etc) but the plants count seems to not be working properly for all the areas (see screenshots attached as an example - logically, the bigger landscape area should have more plants but I'm getting the opposite and re-shaping is providing random results too).
I worked on this file in previous versions of Vectorworks and it was all okay so just wondering if anybody else had the same issue/ found a fix for this?
(For info, this Plant was imported in the drawing while working with the 2021 version. I've been getting the same issue with Landscape Areas using Plant objects created a while ago but re-shaping the area a bit seems to help resolving the issue. The Landscape Areas with this Plant also run very slowly, although when I put this Plant in a Landscape Area which was created prior to VW2021 it works fine, so I'm not sure if the issue is coming from the Landscape Area or the Plant in itself?)
