mocha
    6
Everything posted by mocha
  1. Hi all, Just to follow up on the subject, we're having issues again with Project Sharing & Sharepoint/OneDrive, although (again) we're not sure which one (if not both) is to blame? Every time one of the users is committing her changes to the project file, a copy of it is getting created in the same location of the original (saved on Sharepoint) instead of transferring through to the actual master file. Weirdly enough, she can still see other's users updates when refreshing her working file... but they can't see hers. Given that this is an issue she's been having before with other project sharing files and that nobody else in the office has been experiencing it, we suspect that there is something wrong with the user's settings rather than the files themselves? We're all scratching our heads on this one so any thoughts would be most welcome :)
  2. I'm having regular issues when using the smart edge snapping option. It works fine with lines but when I'm using it with curves, it will every now and then draw the curve edge and then completely freeze the software, obliging me to force quit and restart Vectorworks. I'm on VWX2021 but I had this issue occurring on precious versions as well (2020 and 2019, I would say) and completely different drawings (which makes me think this might not be caused by a corrupted file or the like?). Has anybody else been experiencing this issue and, if so, would have any solution/workaround to suggest? The only way I've found to deal with it at the moment is to have a shortcut for this snapping option to more easily/quickly turn it on and off and so reduce the risk to trigger this bug but it is really not ideal.
  3. It seems that the Landscape Areas are only showing the total plants percentage when using the distribution rate with fixed percentage or rate. It would be really really handy and time saving to have the percentage automatically calculated when using the custom rate / percentage option. My non-math brain is fine doing a bit of mental arithmetic or using a calculator to check I've got my 100% right in 2-3 landscape areas but when it's for dozens of those with as many different mixes, there is always room for an occasional mistake, calculator or not 🤭
  4. Hi Tamsin, I just sent the file to you, many thanks for having a look!
  5. Hi, I've been having issues while creating landscape areas in Vectorworks 2021. The areas created all have the same settings (species, density, unstyled Landscape Area, etc) but the plants count seems to not be working properly for all the areas (see screenshots attached as an example - logically, the bigger landscape area should have more plants but I'm getting the opposite and re-shaping is providing random results too). I worked on this file in previous versions of Vectorworks and it was all okay so just wondering if anybody else had the same issue/ found a fix for this? (For info, this Plant was imported in the drawing while working with the 2021 version. I've been getting the same issue with Landscape Areas using Plant objects created a while ago but re-shaping the area a bit seems to help resolving the issue. The Landscape Areas with this Plant also run very slowly, although when I put this Plant in a Landscape Area which was created prior to VW2021 it works fine, so I'm not sure if the issue is coming from the Landscape Area or the Plant in itself?)
  6. I have received an architect's layout as DWG format which was originally exported from Revit. I have imported the DWG in Vectorworks but the layout I'm getting seems to be overly complex / 'sketchy' - eg. rather than having polygons / polylines, all is drawn with a multitude of small lines, often overlapping over each other as well (see screenshot attached, hope it gives a clearer idea) - which makes it pretty tedious to work on. I was wondering if there is anything which can be done in the import settings to simplify this layout or is the issue more likely to come from the other end, when it was generated from Revit (in this case, would anybody have any Revit export tips which I could relay to the architect?)?
