Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
Kohli
  • Content Count
    21
Everything posted by Kohli
  1. Hi @Wes Gardner im wondering what about the graphics attributes that are assigned to the classes in the templates that have been stripped off? Im currently working on custom template for my company and I think AIA templates would have been a great reference if nothing else.
  2. I have been trying to find the best way to select similar door type, using the select similar tool in VW2020. It doesn't work under object type as it selects all doors. Most likely if there is an IFC tab in the preferences, it should do the trick but there isn't. Any suggestions? Thanks
  3. @Scott Crane Everything looks perfect now!! Thanks for your help!! @gfp38 Ive had similiar problems in the past.. after playing around a lot, I still find adding texture to the walls very complicated. One way I could deal with it is, make class for each component. In the wall settings, assign the classes to each component and choose to apply texture by class. Then for each component, you can apply textures through its class properties. Let me know if this works, or you find a better way.
  4. Hi everyone, I'm facing this somewhat exceptionally strange occurring in VW 2019. Im Using wall tool to create my walls and they appear just fine in the 2D mode but the moment I go to 3D OpenGL 'I can' see walls which are in 2d/3d symbols but not otherwise. Further, if i hover around the supposed position of the wall, it even highlights and I can select them, but cant make them visible. Any suggestions why? I have attached the file just in case. MysteriousWalls.vwx
  5. Found it! I don't know how I missed it.. Thanks for the quick reply 🙂
  6. Is there anyway to click an object and hide the whole class of that object? Or change the behavior of visibility tool to hide the object instead of graying it out? I came across the following thread from 2009 with the same subject but I can't find "Class Invisible" feature in the context click. Im using VW 2019
  7. @Pat Stanford Thanks for the reply Pat. I'm not very familiar with the encoding of fonts and how it works, but if I understand you correctly, the font shouldn't print (or pdf) but on the contrary, I can make a pdf of the single sheet using print command; but it doesn't work for the publishing. Is there a way to define which font should it replace for only unsupported characters, but keep using the same for supported characters. I can, of course, use a different font but that's not what we want to do.
  8. Hi, We use US version of VW 2019. I'm having difficulty using japanese texts in our file. We were using Osaka font, which comes pre-installed on mac and worked fine. But if we use any other ttf japanse font, it works okay for print command but once we publish pdfs, all japanese characters become boxes. Any way to fix it? Thanks!
  9. I see what you mean, which means providing as many of such tools in the base package would avoid causing the issues of editability. I hope the future versions include these exclusive additional features in their base package.
  10. I tried using the class mapping feature on another occasion while i was on vw2018, it wasn't very user-friendly and eventually, I did things manually. Thanks for reminding though, I'll dig into it again on vw2019.
  11. @Boh Thanks for the script. In my case, I directly import DWGs into my project and add a prefix to imported classes from advanced import settings. :3 Are you aware of any other script which allows me to rename multiple classes instead of ALL classes? 🙂
  12. @Art V sorry for my naive question but how can providing tools which are already tested ok elsewhere cause issues with editability of same file format drawings, because of their geographical locations? I honestly fail to understand the real cause behind it but that's not my concern unless i'm provided a software which helps me focus on my design projects rather than unnecessary programming. 🙂
  13. @Jonathan Pickup I don't see the point of paying for Vectorworks and then program to make basic tools. I'll consider talking to the local distributor nicely though it's hardly useful 🙂 Thanks for your time.
  14. @Jonathan Pickup Thanks for the insight, Jonathan. Is there any way to INCLUDE these additional features whenever not available?
  15. @Boh I couldn't find it in the workspace manager. I use US version of Vectorworks, its surprising such a basic feature has been excluded. Is there a way around, to install it as a 3rd party plug-in or something like that?
  16. @Boh I'm sorry I dont see this on my VW 2019 running on mac. Any idea why?
  17. @Jonathan Pickup Yes, Drag & drop is certainly a more intuitive approach to do this. I hope this feature becomes available soon.
  18. Hi @JimW @Pat Stanford This is indeed a simple way to move classes to subclasses but only efficient when you want to move a few classes by manually adding a prefix. I usually import a lot of DWGs and mostly add a prefix to keep them organized once imported from import settings, but I'm wondering how would you move, say 100 classes to sub-classes if it's not done when importing. I hope I'm able to explain well. Thanks Kohli
  19. @Gadzooks Thanks for the response. It's getting much closer to what I want to create. But does this method allows covering or hiding the frame with the panels (acoustic panel in my case) on one of the sides while keeping the frame visible on the other side?
  20. Hi everyone, What is the best way to make walls with the different finishes on either side? I'm trying to make a steel partition with steel finish on one side and acoustic panels on other side but there doesn't seem to be any intuitive way forward. I made a curtain wall, and "assumed" glazing to be steel and further offset it from the frame on one side but I would need "double glazing" to assume the other side to be acoustic panels. Please find the attached image of the custom steel partition I've created. Thanks
  21. Hi everyone, I've been working on VW for about 6 months now but only for 2D, and now making a move to 3D for its BIM capabilities. After hours of trying to make custom steel/glass partitions, I've come here for your suggestions. Attached below is the image of the glass partition I would like to use as a wall style. I dont mind creating it from starch using the parameters VW allows, but they seem to be very limited, especially when I want to change glazing to the steel panel and change the profile of the frame. Could someone please suggest me the best way to do it. Thanks (i cant attached files) Screenshots: https://ibb.co/m1N5gx https://ibb.co/h3wWMx
