Hi All,
I'm baffled. I can no longer choose Open GL in the render mode or any rendering at all. Is it a hardware issue? Running Ryzen 5950X 3.4GHz, 64GB RAM and a Quadro P4000.
Thanks in advance.
Again, Projx_CA saves the day.
I'm really new to this program and finding it difficult to navigate through simple features I was using in Sketch Up, but I'm determined to use this for detailed, and "everyday", designs.
Projx_CA, you're a life saver! This is awesome.
Quick question, I'm looking for the 18' type A curve in a vertical but I can't find it in the files. Do you have this too?
Thanks, Brandon. I'll go through the help menus and see if I can figure out conversion. I thought that might be one of my problems.
Rob, that's great news! AND, I'm a Service Select Customer.
Hey Brandon,
Thanks for the quick reply.
That's the weird part, when I select a piece of truss I don't have a "Draw 3D Only" checkbox in the OIP. Really hoping to find a workaround since all of my installations use Christie truss. Or, is there a similar set of truss in the library that allows for this type of manipulation?
Thanks,
Rex
Hi All,
Newbie question here - I can connect all versions of Christie truss (downloadedx from their site directly) in the top/plan view, but I can't rotate them in 3D space. I can achieve this with other truss objects using the Hanging Angle, but I don't have that option with these objects. HELP!
Thanks in advance,
Rex
