Henslin
    5
Everything posted by Henslin
  1. Hey Nikolay, thank you. That is very helpful. Seems to work well. Thanks!
  2. Hey Guys, just wondering if there was any resolution for this challenge. (Or if we are just doing something incorrectly in ConnectCAD.) I also have he challenge and would love to find a way to not have to re-type all the parameter info for all the devices every time. (I've tried a whole bunch of different ways, but in short, when I have a ConnectCad device in my schematic and create it's 2D version in the 2D rack, then the device grab all the default info from that device and need to re-enter it all again. Any advise please?
  3. Hey All, Stumbled across this thread as I'm trying to resolve what seems to be a similar issue. - Have Vision 2019 installed (updated etc.) - Installed a new copy of Hog software today (Version 3.12.0 b2351) on both, my Hog PC and Road Hog console. - Unable to connect to either my Roadhog 4 or Hog 4 PC (on same computer.) It's been a while since I've connected the console to Vision, but had it all working in the past. Console can't seem to find Vision 2019, no matter what I try. (I am able to connect to Vision 2018 successfully from my Road Hog 4.) - Tried networking through both, Hognet and Fixture net ports (Although, I believe Hognet is the correct port to use) - Tried different IP ranges (Usually use Static IP's but tried DHCP server today as well.) - Tried Re-installing Hog connectivity drivers - 'Run Visualizer Stream' is enabled - Tried different network cables etc (Again, verified all is working as I am able to connect to Vision 2018) - Have disabled all firewall's (Both Windows Firewall and Kaspersky Total security etc.) - Also tried running Artnet signal to Vision instead of Hognet as the dmx provider, no luck. I'd be happy to assist with further investigation as I would really like to get this resolve.
  4. Thanks Eric! Much appreciated.
  5. Hi All, I'm busy working on a project that requires photo-metric data to show if lumens from a proposed light fixture will be enough to light an outdoor artpiece before installation etc. The proposed light fixture (Kim Lighting - Lightvault) is not in the vectorworks stock symbols library, but have found the IES file from manufacturer. I've spend a fair bit of time trying to get this working, to no avail. I've used a standard light fixture (from Vectorworks) and imported the IES file. Tried a side by side comparison to see if any photometric data changed after applying the IES file. Did not work. Then I stumbled upon this discussion. Do I understand correctly that you can import the IES file to help make rendering more accurate, but can't be used for photometric data? If that is so, I would like to ask if this could be considered in a future update release. Is there anyone with a suggestion for me to try perhaps? H.Enslin
