Stani
    4
Everything posted by Stani
  1. Wow, it is working!!! Thank you very much for the help! I was really stuck.
  2. Thank you for the answers, but I'm not sure if I got right how I can make this worksheet. Attached you can find an exmaple of how I want the report to look like (excel file) and what I've been doing in VW. Pat, could you give me an example or explain more your suggestion? Wall segment.xlsx Wall segments.vwx
  3. Hi, I'm a Store Designer and currently working on database on our inventories in Vectorworks. I face an issue with the worksheets as I would like to combine a record files and instead of columns to convert them in rows. For example: there is a wall segment with a record data with different components. When I make a report all components come as different columns instead of different rows. Could you give me some guidelines how I can make the worksheet to contain the different wall segements and all componenets in rows instead of columns? Do I need to make a customized worksheet and set for each cell the different componenet? Or is it possible to make different worksheets for each wall segment and link them to a main worksheet? Hope that somebody can help me.
  4. Hi, I have the same problem and already tried to save my Sketchup file in all versions from Sketchup 4 up to Sketchup 2017 and import in Vectorworks 2017. None of them worked. I get the same error message that the file is damaged or unsupported. Tried the same with a simple file made in Sketchup and the result was the same. Could you help me?
