livespace josha
    151
Reputation
68 Excellent
Personal Information
  • Location
    United States
Recent Profile Visitors
  1. Love the way you can duplicate a Title Block Border to multiple sheet layers with a few clicks. Can this function be expanded to more {or all} objects? examples: I've got a graphical legend for my lighting fixtures, and 5 or 6 sheet layers I'd like to put it on. I've got some geometry (polylines, rectangles, etc) for divisions on a sheet layer. I'd like to duplicate that to multiple sheets so they all look the same.
  2. Two requests for soft goods objects, specifically when changed to pipe and drape: - Can they by default NEVER attach to a hanging position or be associated to any rigging object? - Can they default to 0' elevation unless you specifically over-ride the Z setting? I've lost count on the number of times I've had to reset p&d back to 0' Z or had a drape line move when I moved a truss...
  3. Hey @TomWhiteLight I was about to write a lengthy question, then I saw this post. I think this explains the issue I'm having. Let me describe my application, maybe there is another option: Working on a event where we're doing multiple truss "systems". 15 in total, of about 4 different designs. I designed up system 1, converted to a hanging position and had that tool create a symbol for me. Duplicated and moved the hanging position as needed, and gave it a unique name. Same for the other systems. I went the symbol route because I'm able to edit multiple objects as the design changes. I need to pull a report. I want to list out count, truss length, vendor, color and {most importantly} what system it is a part of. But... I can't use class, because that will list the class the truss is in. I can't seem to find an option to list what symbol or hanging position it is in. I also can't seem to "go the other way" and list what items that are in a symbol/hanging position. (side note....this feature would be super handy to list everything associated with a hanging position...cables, lights, truss, hardware, etc.) The only thing I can make work is by assigning everything to its own layer. Possible, but that's gonna require quite a bit of re-work at this phase. Thoughts?
  4. ....and: There are some items (Chamsys MQ500 lighting console comes to mind) have symbols within that symbol. ...and gradients ...and textures ...and record formats I'd love to have a "Lighting Control Chamsys MQ500" folder in my resource manager holding everything related to that imported resource. Maybe a "Nest all imported object into single folder" option when importing that resource?
  5. Can we have some more options for folders in the resource manager? Currently we're limited to only having "things" of a certain "type" in a folder. This limitation seems arbitrary and limiting for no reason*. There are situations where this is super useful and I don't see a need to change, but expanding on this would be nice. My use case that prompted this request: I have symbols for revisions (version 1, 2, 3, etc..). This has a record attached noting details and what trade is effected. I have worksheets for each version that populate with page number and the fields from the record. My resource manager is a mess because I either have: - all these objects in the root level of my resource manager - 3 different folders (symbols, records, worksheets) I'd love to have a folder named "Revision items" and everything (symbols, record formats and worksheets) in one place. *if I'm wrong about this, I'm interested in know what happens under the hood!
  6. Yes, running 2 external monitors. Yes, many applications open... Safari, Preview, email, project management software, etc. I'll keep experimenting on my end to see if I can recreate reliably or try some things if it does happen again.
  7. @jblock Sonoma 14.2.1 I've had this happen twice on accident, but never when I've intentionally tried to make it happen. I'll keep trying to see if I can recreate it and under what circumstances it happens.
  8. 2024, most recent service pack. Confirmed issue on multiple files and multiple re-boots. Select a symbol Run the "Modify->Convert->Replace with symbol" command Select symbol, hit OK Immediately run the "Replace with symbol" command again, and Vectorworks freezes.
  9. 2024 sp3.1 (but also had this issue on previous 2024 builds..) When using the "Origin-User Origin" command, a pop-up window appears for data entry or to interact with. At times, I am not able to interact with that window. "Cancel" and "OK" buttons do not work. Close window (red button) does not work. Hitting the ESC key closes the window and all functionality resume. I've found this issue repeatable, but not sure under what circumstances. 50/50 if the command works on the 2nd time.
  10. Thanks @Conrad Preen and @Nikolay Zhelyazkov. Funny story...while at the gym after work I thought: "I bet if I modify the circuit type's class, it will work!" Thinking more about it... A cool feature would be a global "Circuit Style" that could affect all circuits, not on just on a class-by-class basis. I know Vectorworks {as a whole} is migrating towards the "style" route for many items like viewports, windows, walls, etc. Maybe some ConnectCAD items follow? But still being able to edit those individually is still needed. The option to have the bubble be a solid fill is a nice idea. Map the fill color to a data visualization for field vs. rack cables? Or new vs. existing cabling? ConnectCAD sure has come a long way... Just dug through my archive, and my first license came through June 2017!
  11. Looking at modifying my circuit bubble graphics. The "Connector" and "Number" classes edit the look of the corresponding items in the circuit, but nothing seems to affect the bubble (I use mine for Cable Type). Just looking at doing basic stuff like font type, fill, size, etc. Is this something that is: - Locked? - Editable by the "Edit Circuit Graphics" dialog box using script or commands? (if so, is there a resource for those commands?) - Something coming in a future release?
  12. @Nikolay Zhelyazkov here 'ya go! I edited the cp_IN and cp_OUT symbols in the "System Symbols" folder. New CP's take the updated layout, but ones already in the file don't auto update. CP update issue.vwx
  13. Working on a very busy/complicated drawing... my stock connector panel lables aren't going to work, so I'm editing the layout(s). I already have a number of connector panels in the drawing. If I edit the cp_IN and cp_OUT symbols, the devices in my drawing do not auto-update. However, if I place a new connector panel, they show up as edited. Is there a way to force the devices to update to the new symbols, or is there an "auto-update" feature somewhere?
  14. Slightly out of date, but this video covers the gist of it. in a nutshell: create class create texture edit fixture 3d symbol {assign texture to lens, re-class it} modify spotlight preferences as described it's one of those things that I can never commit to memory, so I have to watch the video every time I do it!
  15. Title describes the thing. If you use the "Select lighting devices by fixture type" or "Select lighting devices by position" command, fixtures assigned to a class that is greyed out will also be selected. Luckily an Undo restored by entire lighting rig after I accidentally deleted it!
