UPDATE: I now have VW2018 and see many of the same problems, with new ones thrown in.
Let me review. When a part becomes “complicated” with many edits, VW refuses to do a lot of things, such as add, subtract, fillet, chamfer, PPT, even highlight a selected object. ALL my parts are complicated. They are the components of a microscope stage, with multiple parts, holes, curves, etc. I can’t do design any other way - I have to fit them together, look at views for conflicts, then modify. The conflicts sometimes require adding a hole, or extending a surface, or moving something to a different location. I may move/create parts in separate dwgs, then bring them back to the assembly file for “testing”.
For example, sometimes the PPT will highlight an object, show the extension menu in or out, accept a typed distance, then do nothing when asked to execute. The same surface may pull/push if I use a large number, then p/p back to the original desired location. Sometimes it will pull out and not go back. Sometimes fillet will accept all the inputs, but refuse to execute (no messages), but chamfer will work on the same edge.
The best workarounds I have found so far are generic solids, which works about 30% of the time. Intersect solids seems to work better and do about the same thing.
In VW 18 I am having slowdowns/freezes that can last 20 minutes. For example, I highlighted an object to change the line width and color. It froze for ~15 minutes. The same can happen when I cut and paste an object from an assembly dwg to a new file with only one simple part in it. 5-20 minute waits have happened for it to paste the object in the new file. Dosen’t seem to be related to the object size.
I have begun monitoring the Activity Monitor on my MBP to see if I can tell what the prcessor is doing, or the memory, etc. My computer is a 2013 MBP with retina screen,16GB RAM, i7 @ 2.6 GHz, 1TB SSD drive, so it shouldn’t be underpowered. I am also powering a 28” 4k monitor and a 28” 1080 monitor. I know that is a lot of monitor, and I heard from VW that they are having problems with 4k external monitors (back in vw17). So, I have tested using no external monitors ( a little better) and using one 1080 monitor only. Still have problems.
My Vectorworks/ %CPU register frequently shows 150-180% when the program is hung up on the simplest tasks. It must be running around in never-never land, but there is no “not responding” message.
My memory usage shows 8GB when I first start VW (all other pgms shut down - browser, mail, etc.). The first file below is 4.65GB, and the total RAM used jumps to 12-13GB. Note that the file of just the right side of the assembly (2nd pic) is 4.32GB. This can’t be true. When both files are active, the RAM still shows ~13GB. The total memory usage by VW is 40GB. RAM and SSD.
I have tried rebooting (warm and cold) and things improve in the short term, then go downhill.
Ideas?
