DavidT
8 -
Reputation
0 NeutralPersonal Information
Location
United States
Recent Profile Visitors
Thank you! There was a glitch that was preventing it from operating correctly. It's working now. Thank you!
I've rotated a shape I've created and now I want to plate the screen view. When I draw a box around the shape to create a viewport, VW plates the entire design layer with a red striped update box. Is there an easy way to bring in a custom iso view?
Thank you! That was my problem. By unchecking the automatic drawing coordination, I was able to manually edit each label without any problems. Thank you so much.
I'm trying to label my plan, elevation and section but every time I edit the label name or number, the previous labels change names or numbers. It's like they are linked and I am not able to simply edit the labels. Even if I manage to somehow get them to all be correct, at least one of the labels will automatically change and the finished pdf will be incorrect. Has anyone else had this problem? Is there something I am missing? Is there a way to unlink the labels? Thank you!
I'm adding dimensions to a complicated drawing with curves. I'm using the arc dimension tool but the arrows are so big and I don't know how to change their size or appearance. Can you help me? David
Thank you! You rock!
- 4 replies
- flyovertool
- xyzaxis
(and 1 more)
Tagged with:
Ahh.. that makes sense. How can I change modes? David
- 4 replies
- flyovertool
- xyzaxis
(and 1 more)
Tagged with:
When using the flyover tool, I like to double click to change the location of the xyz axis so that I can zero in on the objects center. I'm not sure why, but I'm not able to double click and move the axis anymore. Is there a setting for this? Thank you!
- 4 replies
- flyovertool
- xyzaxis
(and 1 more)
Tagged with:
