445 -
Posts posted by Wesley Burrows
4 minutes ago, Kevin McAllister said:
Hi Nikolay,
I should clarify my response. The workaround works (all controls) but the original problem is not fixed.
Kevin
My experience mirrors that of Kevin's.
How on earth does one install the current version of cloud services? The release notes on the portal say that 6.10 is current.
But whenever I download the "current" version from: https://cloud.vectorworks.net/download/latest/Mac
This is what installs:
I'm not a Vectorscript wizard by any stretch, but it seems like a vectorscript should be able to take a selection of lights as input, step through each one, grabbing the x, y rotations from it, storing them as a variable, convert it back to a symbol, and then 3D rotate it back with the stored x, y rotations, then rinse and repeat it's way through the rest of the selection.
Perhaps this should also be a wishlist item. I would imagine it's "working as designed" but I can't think of any reason why the current functionality would be desired over the proposed rotated result.
Did you ever figure out a way to work around this Evan?
2019 SP0 Update:
I have been able to export successfully 4 times and counting so far without a VW restart! Dare I say this bug has been fixed? Anyone else?
35 minutes ago, Jim Wilson said:
If you switch to another workspace thats unmodified in any way, edit the arrangement, shutdown Vectorworks, then relaunch, does it still move? I've been unable to replicate this one on Mac or Windows since the beta of 2019 but I just got another report of it today.
If that still happens, if you undock the OIP, adjust the data tab arrangement, then restart Vectorworks does it still collapse again?
Default Braceworks: Adjusted Braceworks: After VW Restart:
So yes, it appears to work with a default workspace. Though my 2019 workspace started as the default spotlight workspace. I modified it vs importing an old one.
I, like you, attempt to screw around with it about once a year, and I can almost never get it to work right. Then I give up, cause I actually need to get stuff done. I got hopeful with the last update as it said that they fixed problem with Dropbox for Business integration. But nope, I still get stuff like this all the time. The file's live in dropbox, they are always sync'd. VW Cloud has full integration to my Dropbox for business account. Then I get pissed at it and move on. I can see the value of it, I would like it to work. But so far, no good.
Edited to add, I can get the Nomad app to output PDFs but then it just outputs everything. No way to control it. Just like what you were saying. That's what is confusing because you are supposed to be able to publish from VW like you usually would choosing your sheet set and telling it to process and store via the cloud:
But even when I have that selected I still get this crap:
Maybe you'll have better luck?
I run dual 27" 2K screens on my Mac. I Tried a 4K monitor and I found everything too small, (I even used 55" 4K TV for a minute, that was comical) Most of the time I'm operating VW on one screen and have all of my reference material on the on the other. In 2018 I would say there definitely was an overall performance/stability hit when the second display was plugged in, but VW was the only app I experienced this with. So far, 2019 seems to behave better with this configuration than 2018 ever did.
- 2
I've actually had a mildly pleasant experience with 2019 thus far. I wasn't planning on using it right now, but out of sheer desperation with the complete failure that is 2018 SP4, I tried it and so far I haven't had nearly the number of beachballs per hour as 2018. Switching sheet layers is stupid slow though, 30 seconds or something. And the "new" to braceworks Structural Member tool doesn't work. I'm sure there are other things. Time will tell...
It's somewhat self explanatory. But I recommend a healthy amount of patience when you start to get in to it. You also have to pay pretty good attention to what you're doing to make sure loads really are added where you expected them and stuff. It seems to behave a bit more like you would expect it to in 2019. There were quite a few idiosyncrasies with the behaviour of things initially and though improved in 2019, I imagine many are still to be found when I have time to start running it through the ringer. So a lot of patience, and a healthy amount of double checking.
Along these lines I don't understand why you can't (or I can't) seem to get a single hoist to grab the load info from the Line Array tool let alone connect to it. (single point array). If I stick a point load under the hoist with the weight of the array and same Z value of the motor, that works. What am I doing wrong? Or is it really that stupid?
I agree with you, typically, the "open beta" ends up being the official release until service pack 2 or so. Something like Release SP0 = Open Beta, SP1 = Release Candidate.
- 1
Just now, markdd said:
My understanding is that they are one an the same....
Interesting. Since I can't actually draw anything with it, it's hard to say 🙂 My apologies for incorrect information.
As Scott said this is precisely the functionality the Braceworks module provides. It’s a great tool to be sure, and has been much improved since it’s initial release, but it is still relatively in its infancy. And as such it can’t handle all rigging situations you might encounter in the real world, but for those it does, it does well.
- 1
I suspect you are referring to the AEC structural member tool. We are referring to the entertainment rigging one. There are several tools in VW that share similar names but with somewhat different functionality. Confusing for sure.
Agreed! Up-voted.
I only attempted to mess with this for a moment but I too was unable to draw anything.
I would imagine it would be generating a worksheet in Vectorworks with the info you want, exporting a CSV delimited version of it. Then use Microsoft Word mail merge (or similar), with that CSV as the data source. And format how the labels look/what size label.
Time for Nemetschek to stagger releases with Apple
Posted · Edited by Wesley Burrows
I have said this too.. SP0 = Beta 1, SP1 = Beta 2/Release Candidate 1, SP2 Release Candidate 2/Release etc.
I agree, and really hope they expand. It is pretty amazing to me the number of bugs/tools not working I have found within an hour of using a release, many of which I'm fairly astounded no one found. This latest 2019 SP1 update definitely felt more like a hotfix style/less intrusive update, which I like, it also felt like it came out much faster than previous SP1s, I'm pretty sure the last two SP1s at least were around Thanksgiving each year.
