391 -
Posts posted by BG
Is there any update on whether back referencing is going to be added in 2018? We were requested recently by a Council processing one of our Building Consents to include back references on all details. This took considerable time and of course, they are all manually added, so no automatic coordination.
This doesn't seem like a major to implement.
Thanks
1
There is a roof truss PIO at Vector Depot http://www.vectordepot.com/older_plug-ins.html
Just standard type though, not parallel or scissor etc.
Hi Jim, is there any plans on addressing this issue in a future update?
Kind of defeats the purpose of sharing a file if it becomes unusable.
Thanks
Brett
Hi
We are using project sharing on a fairly large residential project. The file is currently around 100 MB and the project file is saved on our NAS drive.
We only have 2 working files, but we are noticing a 3-4 second lag when even doing the most minor drawing changes, and the information bar at the bottom of the screen says 'waiting for project file'.
Is a setting we can try, to avoid the lag? Working on the file now is painful.
Thanks
Would love this to be an option, although when a detail is referenced from multiple locations, you would have to have the option of choosing one back reference? We used to always back reference our details until we started using linked details.
Just realised that the printer setup scale also affects the placing of text using text styles, and placing hatch patterns. If the printer scale is set to 50%, they are all double the size.
Be preferable not to have the printer scale affect drawing, but at least we know why the odd behaviour now. Been annoying us for a long time.
Hi Josh
I just opened your file and it works perfectly fine for me. Are you on a MAC? We're on PC's.
Brett
Hi
We have our dimension standard setup with a text style with text set to 7pt.
When placing dimensions, the size of the text actually placed on the drawing is related to the print scale currently set in the print setup. i.e if the print scale is set to 50% the size of the dimension text placed is 14pt. It varies depending on the current print scale. If it's set to 100% the text placed is at the correct size.
Has anyone come across this issue? Can't understand why it works like this?
Thanks
Hi. Am I correct in that, the only way to change the % of the slope faces once created, is either to delete the drains & re-create the slab drainage with a new slope % or manually adjust the valley slopes until you get close to the slope face % desired?
Or is there a way to change the slope face %?
Thanks
Thanks, I was sure there must be a way to control that, but couldn't find it! :-)
Hi, when searching the Resource Manager, how do you choose where the RM searches?
Thanks
That's clever. Thanks. Brett
Hi Alan, can you confirm how this should work. I know nothing about Marionette so sorry for the basic questions.
In your schedule 001, there was a marionette string plus a marionette object - & in the OIP you could specify the space between the windows.
In your schedule 002, there are 2 marionette strings, but no marionette object. The windows created are now groups and there isn't the option to specify the distance between.
Can you please just explain the correct way to use this in a different file?
Thank you
Brett
Thanks Alan, will try that out.
Attached is a sample schedule.
Cheers Brett
Hi Alan, we've had a quick trial with your marionette window schedule & it looks promising - nice work.
Just wondering, we number our windows on the plans in an anti-clockwise direction so that in elevation & on the window schedule they are going from left to right in the correct sequence.
The marionette script places the windows from left to right.
Is there a way an option could be added to place the windows from right to left? So that when the section viewport is created, they appear in the correct order.
Thanks
Brett
Thanks Alan, some good tips.
Cheers
This is how we use the Callout/Notes Manager to only have one legend for the whole set of drawings.
After we place the first callout, we move the legend on to a design layer, and then we viewport that legend on to whatever sheet we want to see it on.
The callouts are placed on to design layers and/or sheet layers (in the annotation space). Once we have one callout placed, we just copy and paste it as required and update the callout text from the Database. If we need another Note, we add it on the fly in the Notes Manager.
Note, we use the 'Description' field for numbering the callouts - so they are manually numbered in the format we want.
It's a bit cumbersome, but it works. Ideally, the callouts would be always linked to the database, so if the database changed, the callouts would change too. Sadly it doesn't work this way and once you've placed a callout, it is no longer linked to the database.
2
What tool do people use to model balustrades? Tried using the Railing/Fence tool, but encountered some unexpected behaviour.
Corner posts - trying to make the railing go around a 90 degree corner (or any other angle) with a post in the corner doesn't work. The post ends up on an odd angle.
Why can't you use the eyedropper to copy the plugin parameters from one railing to another?
When turning off either the starting post or the ending post or any other combination causes the top rail to 'disappear, or the railing to not show at all. This doesn't seem to happen on all configurations.
My file is attached. Maybe someone can see what setting I have wrong?
Or is there a better tool?
Thanks
We have the same issue, any speed improvement on this would be welcome.
It's not a huge deal, but with some tools you cannot TAB between fields in the Object Info palette.
Haven't noted exactly which ones are like this, but The Drawing Label & Revision Marker tool's are examples, I'm sure there are others. It's a pain (& slow) having to click with the mouse to enter the next field.
This has got our vote for 2018. I think it's been mentioned, but automatically showing the floor level lines on elevations and sections is also a 'basic' function currently missing.
2
We've experienced this too.
Back Referencing
Posted
+1,000,000,000 also!
