44 -
Posts posted by Francisco J. D. Rogers
On 6/14/2017 at 0:04 PM, RGyori said:
Hello
Im working with VW in a MacBook Pro and an iMac with High Sierra. All works fine except an issue in the Info Palette
On 6/14/2017 at 0:04 PM, RGyori said:Probably for Jim...
With the introduction of new iMacs, and the end-of-year iMac Pro, is/will VW2017 be compatible with High Sierra?
Of particular concern is the new file system Apple is introducing as evidenced by Microsoft's stated limitations: http://appleinsider.com/articles/17/06/13/high-sierra-leaves-microsoft-office-for-mac-2011-behind-2016-edition-needs-updating
Sorry; But where in the Library?
Hello Robert:
In my experience a good BIM Design Team must work with two CAD platforms. Not in parallel but complementing each other. And using the same information model shared via IFC.
For example: The Building architecture, structural model and electrical devises; are made in VectorWorks. And MEP in other software like Data Design System from Nemetschek as well.
When work with other professionals like Civil Engineers ( that may use REVIT and SAP2000 for example ), VectorWorks export to IFC, SAP or REVIT natively, then I never had have troubles.Then go ahead and be sure all will works fine.
Best regards
6 minutes ago, michaelk said:
Yep.
The Space name is =('Space'.'11_NameDisplay')
The Occupancy Org is =('Space'.'11_OccupantDisplay')
The Occupant is =('Space'.'11_Occupancy Type')
Thanks a lot
Hello to all:
In the Space polygon, I set Space Name, Occupancy Org and Occupant. There are any way to put them in the Worksheet like the Name and Area?
Hello to all:
My expertise is developing all the architectural design with VectorWorks and sharing with SOLIBRI and FRAMECAD STRUCTURE to produce the steel framing in automatizad way.
Regards -
And if do you want set for example: 10.2453300123 to 10.25?
Round cuts ALL DECIMALS and set to zero.
Hello:
By the way, what is the syntax for show the symbol name in a Worksheet?
cheers
Then we must wait for it. I hope works fine. Other thing, I want migrate to 2017, but in Chile the projects are going less each day.
Cheers
Exactly: We then must pay for use!
Sorry: You are running VectorWorks 2016 on OSX Sierra?
How is it? I tried a very times after update my Mac to run VW 2016, but nothing happens. The app icon even do not bounce on the dock. After that appears an error log and crash.
High Siera Compatibility?
in General Discussion
Posted
Jim:
I am using an iMac 2013 and a MacBook Pro 17 2011. Both with High Sierra.
VW 2017 works fine and as always except with an issue in the Info Palette. When click on a rectangle for example, the section points in the Info Palette are bad positioned.
