Paolo
  • Content Count
    71
Everything posted by Paolo
  1. There is some new on this subject here: Mouldings plugins on Vectordepot Seems promising...
  2. Thank for your answer, Raymond, Ok to scale the line from midpoint, but the problem is elsewhere. LineLineIntersection is good for polygons, not for polyline with curved strokes, as far as I know, Split2DObjectByLine is the natural way, but it sometimes fails ( read here in the VectorScript Function Reference, annotated version) . Paolo
  3. I need to get the first intersection point (if any) of a polyline with a given line (extended if needed) via VectorScript. I have tried to use the Split2DObjectByLine procedure, but it seems not reliable. Here's the script. To test it, draw a polyline, then a line, run the script and select first the poly then the line. A point should be placed at their intersection. Not always it works. Sometimes it even crashes VectorWorks : procedure lineToPoly; VAR polyHandle: handle; lineHandle: handle; punto :Point; function intersectionLinePoly(lineH, polyH: Handle): Point; VAR tmpPolyH, tmpLineH : handle; begPt : point; endPt: point; resultHandle, temp_h: handle; BEGIN {faccio copia della linea} tmpPolyH := CreateDuplicateObject(polyH, NIL); tmpLineH := CreateDuplicateObject(lineH, NIL); GetSegPt1(tmpLineH, begPt.x, begPt.y); HScale2D(tmpLineH, begPt.x, begPt.y, 10,10,false); GetSegPt2(tmpLineH, endPt.x, endPt.y); Split2DObjectByLine(tmpPolyH, begPt.x, begPt.y, endPt.x, endPt.y, resultHandle); IF resultHandle <> NIL THEN BEGIN GetPolyPt(resultHandle, getVertNum(resultHandle), intersectionLinePoly.x, intersectionLinePoly.y); END; delObject(tmpLineH); delObject(tmpPolyH); END; begin GetPt(punto.x, punto.y); polyHandle:= PickObject(punto.x, punto.y); GetPt(punto.x, punto.y); lineHandle:= PickObject(punto.x, punto.y); punto := intersectionLinePoly(lineHandle, polyHandle); if not ((punto.x = 0) and (punto.y = 0)) then locus(punto.x, punto.y); end; run(lineToPoly); Is there a more reliable way to get this? Thank you in advance for your help.
  4. Try this: http://www.vectordepot.com/market/vm-034_adobe_illustrator_im.html
  5. Can I invert a NURBS curve direction with VectorScript? With polys it is easy, with a "downto for cycle" through all components points, you can get another poly assigning point in the inverted order, but with NURBS? Thank you for your help. Paolo
  6. I have the same Designjet HP 500PS and the same problem that I solved. To get exact A0, A1, A2, A3 I have create my custom equivalent formats including the margins that are (for the HP 500PS) 1.7 cm (top and bottom) and 0.5 cm (left and right). For example A3 Horizontal trimmed is 42x29.7 cm, including margins is 43x33.1 cm. Doing this way it works. Another way is to print to PDF and using a simple layout program like this (Mac only): http://digilander.libero.it/kiaradot/fitplot/Contents/Resources/English.lproj/fitPlot%20help/index.htm The advantage is that you may print more drawing at once optimizing paper waste and having the margins under control.
  7. Your suggestion has been the key! Thank you! Here's a procedure to increase all the extruded object in a selection of a user given value: [font:Courier New]procedure increaseExtr; {the goal is to increase extruded objects in the selection of a user requested value} var oggetto:HANDLE; increaseValue : REAL; FUNCTION increase(h:HANDLE):BOOLEAN; var height,width,depth:REAL; xRot, yRot, zRot:REAL; p0X, p0Y, p0Z: REAL; p1X, p1Y, p1Z: REAL; result, isMirroredXY: BOOLEAN; begin {check if the obj is an extrusion} if (GetType(h) = 24) then BEGIN result := Get3DOrientation(h, xRot, yRot, zRot, isMirroredXY); Get3DCntr(h, p0X, p0Y, p0Z); SetRot3D(h, 0,0,0 , 0,0,0); {here depth = extrusion value} Get3DInfo(h, height,width,depth); {I increase the depth} Set3DInfo(h, height,width,depth+increaseValue); Set3DRot(h, xRot, yRot, zRot , 0,0,0); Get3DCntr(h, p1X, p1Y, p1Z); {move of the misplacement p0-p1} Move3DObj(h, p0X-p1X, p0Y-p1Y, p0Z-p1Z); Get3DCntr(h, p1X, p1Y, p1Z); END; increase := FALSE; end; begin {ask the value to increase} increaseValue := RealDialog('Increase extrusions in the selection of this value','10'); {apply to the selected set of objects} ForEachObjectInList(increase, 2, 0, oggetto); end; run(increaseExtr);[/font]
  8. Hi all, Is it possible to get the extrusion value of an extruded object in VectorScript? I have checked the VectorScript Reference but found nothing appropriate. Thanks for your help!
  9. There is a plugin to import .ai or .art files (it imports in VW just the paths, not fills, texts and other graphic attributes) at vectordepot: http://www.vectordepot.com/plug-ins/ There it is a demo and a complete version in the market section.
  10. Go to VectorDepot and browse for a program called Logex. Logex reads and analyze the VectorWorks log file extracting from it all saved drawings on which you have spent more than 1 minute. A typical output could be this: fileX 23/05/2006 20:39 00:33 fileY 23/05/2006 20:42 00:11 Untitled 1 23/05/2006 20:42 00:01 fileZ 23/05/2006 20:42 00:25 Once saved, the output is a text file with each line representing an event (drawing) record. The record fields are: the name of file (drawing) the when (date of event) the time spent for that file Fields are TAB separated, so the file is ready to be used in a database or in a worksheet for further statistics. Logex analyze the integrity of the VectorWorks log and check if there are errors (due to VectorWorks crashes or possible deactivations / activations of report from the VectorWorks general preferences). Errors are classified by a color syntax that may be helping for the correction work. Presently logex is available only on Mac OSX? 10.3.9 or more, any version of VectorWorks? (version 12 with some limitations due to a known bug in the "saved as?" lines produced in the report). There is no way for Windows users. Logex is available in Italian and English localization.
  11. I have worked on the problem and went out with a plugin that is able to import paths from files saved as .ai or .art from Illustrator?, FreeHand? and other vectorial programs. The importer is avaliable here: VectorDepot There is a free evaluation copy too (limited in the number of entities it can import). Waiting for a true usable quadratic bezier tool in VectorWorks, this can be a workaround for all of those users that can draw their artworks with other programs.
  12. At Vector Depot there is a set of script to help generate and dimension exploded isometric view. It has an isometric dimensioning tool that uses islandmon algorithm. http://www.vectordepot.com/market/vm-017_explosion_tools.html It works only on isometric views (snapping on 3D edges along XY or Z planes). It's a workaround waiting for a native 3D dimensioning from NNA.
  13. Paolo
    PDF's from Mac
    Try this too FitPlot It is useful to send PDFs to the plotter framing them into the plotter sheet area.
  14. I'have tried this little experiment : Made a Bezier shape in FreeHand (5 points, 2 nibs and 1 bezier point with 2 handle points). Exported as .ai (even .ps or .eps should work). Opened in Textwrangler (or similar text editor). Found the clearly visible sequence of 5 points. Opened Vectorworks and created a similar shape (polyline tool) with this sequence: angle point, bezier point, angle point, bezier point, angle point. Modified each point coordinate according with values of the .ai file. The obtained curve should now be the same as in FreeHand, but a superimposition of the two shapes (proportionally rescaled) reveals a mild difference. Conclusion: bezier's algorithm used by the two programs are different!
  15. Or, at least, I wish an Illustrator / Freehand importing tool. I currently use Freehand beziers for logos and free forms, then I export in Illustrator format. I import it in Cinema4D (a very old version I use just for this) and export from there as dxf. When I open the dxf in Vectorworks, alas, the bezier lines are all converted into polygons (segmented in thousands pieces). I suspect there is no satisfactory algorithm to convert true beziers (such used in Illustrator, Freehand, Photoshop) into the native bicubic spline engine of Vectorworks.
  16. VectorDepot has published an instruction / explaination file about "openings" plugins set (including the wall niche option). The link is here: Opening plugin (wall niche) readMe
  17. I agree with you, Robert, the name "Openings" for the plugin's set may be confusing, but niche is an option available in a general, very customizable, opening in the wall. here's th info panel of the plugin and same image respectively in plan view, dashed line and openGL renderings. Hope now it's clear.
  18. Are the VW Architect door and window tools able to do a wall niche? If yes, why don't you tell us before?
  19. The plugin I mentioned is now available on Vectordepot VM-030 Openings
  20. Paolo
    none class
    Yes, of course, these are the only two obligatory and undeletable classes, always present in any VW document. You cannot even change their names, though you can change graphic attributes.
  21. Paolo
    none class
    I have found it by myself! classlist(1) gives the string of the "none" class
  22. Paolo
    none class
    Is there a programatical way to get the "none" class name? This is useful for plugin localization. In italian "none" become "nessuna" and so on for other languages. Is it possible that this special class (it is always present and you cannot delete it!) has not a VectorScript instruction for retrieving its localized name? Thank you for your help, Paolo
  23. Yes, I'll try to publish it at VectorDepot, but the site is under heavy remake at the moment. If you can't wait, write me at project@arcoarredamenti.it. Paolo
  24. I have made, some time ago, a plugin that fits your needs. It can create parametric niches or openings with splays (also aymmetric) and vault of various kinds. I can't attach the plug in directly here. Let me know how to send it to you. Ciao,
  25. Thank you Katie, can you tell me since which version this bug was introduced?
