456 -
Posts posted by bjoerka
this works now after installing SP1
- 1
Janvin,
as i remember (in the meantime we also switched to VW2016) most of the problems were gone. Sometimes with 2015 we had problems that some files have been marked as "the file is currently in use by xxx".
We got rid of that by setting the user permissions on mac from normal user to administrative user. Vectroworks has been writing some settings to locations in the system folder to which the normal user wasn´t allowed to.
After we switched to 2016 these problems also have gone.
So finally - SMB is what we are using for all workstations.
i tried to export a HDRI rendering with VW2017 and only get 2 empty files?
The "a-" file (alpha i suppose) is black and the regular file is filled with white...
The same file works with VW2016.
awesome Jim! That was a easy and fast solution .-)
Thank you!!!
does anybody know a solution how to convert a point cloud file that was delivered in ply format to any other that can be read by vectorworks?
our client told me that he is unable to do it....
any help is welcome .-)
i dropped you a link with the file and another screenrecording.
hi zoomer,
i had this behaviour according to the cameras within the last three weeks in 3 projects.
all 3 projects were started from scratch in VW2016.
nothing that was copied from a previous version.
mostly when i come across things like that, i do an export as textfile and reimport that into a new empty file, so that i can see if any error occurs. did this here also and no error came up.
so i think that it may be related to some other things inside vw2016.
i´ll see what Jim´s answer will be...
Yes Jim,
the second camera that was placed, got flipped by 180deg. after switching back to 2d plan...
similar problem here.
working on a 3d model which is rotated 270deg. in 2d plan.
place a camera and activate it. then deactivate it
switch to a view from left, right i.e. via keyboard
switch back to 2d plan and the camera is rotated as if the 2d plan is rotated back to it´s origin...
see also the attached screenrecord.
VW2016 SP3
Thank you Jim!
yes... this is 2016 !!!
and not fixed with SP3 :-(
I have encountered a problem with the seating tool.
When you enter a value for the seat spacing, the entered value is never exactly the amount you enter in the information window. The amount for the row spacing always matches.
Is that a known issue or am i doing something wrong?
There is a new servicepack for 2015 available that is supposed to get compatibility for OSX 10.11.
Has anyone already tested this?
thx Jim ;-)
Service Pack 1 for Vectorworks 2016 has been released, you can get it here:
http://www.vectorworks.net/downloads/ServicePack.php?major=2016&servicepack=1
As of this service pack, Vectorworks 2016 has been made compatible with OS X 10.11 El Capitan.
any news about a service pack for 2015 to get compatibilty with el capitan?
maybe someone can confirm this.
activate the straight truss tool
do the first click somewhere
hit the tab key to enter a value
the floating bar changes to coordinates for entering the first point.
somebody else get´s this?
What is the menue "Cloud" for?
When i got to "Log in" nothing happens...
does anybody know how the size of the marionette icons can be changed? for me they are quite small compared to the geometry when you are working in scales by 1:100 i.e.
all libraries installed and vw started.
migration manager :-) nice one!
downloading in germany :-)
1.3gb installer was done in 45seconds. the libraries take a bit longer...
same on my vss account. serial number is available. download section still showing sp4 for vw2015 ;-)
ok. Thanks for the answer.
Is there an initial release date already?
Drag and drop with RW Materials not working properly
in Known Issues
Posted
when i try to place a RW material with d&d i can not get access to objects that are in visible front to one in the back.
when i rotate the view to get the object standing clear to the background it works. otherwise the object which covers most of the view is activated.
watch the video to see what i mean exactly
happens in wireframe and open-gl
VW2017 SP1
DragDropRenderMat.mp4
