456 -
Posts posted by bjoerka
report and file is sent...
hi tim,
i´ll post mine tomorrow when i am in the office. German time zone ,-)
is there any way to get something similar from the windows side too?
Hi Nina,
that seems to work 😉
I even didn´t try to save - close and reopen that file.
thanks.
best,
bjoern
oh wow. dwg into 2017 was never a problem at all.
also when i import this specific file into 2017 and 2018 it appears to be ok.
thanks for the workaround.
another one is to edit the symbol, nudge the geometry with the keyboard right and left and exit the symbol.
after that the ghosting disappears (mostly) too.
but i am aware to do this with huge dwg imports...
hopefully things in 2019 will speed up with the upcoming service packs... sp2 is terrible slow...
today i received a small dwg which is totally messed up after the import.
geometry is shifted / ghosted, after editing symbols drawn twice on the screen.
changed several import options, but nothing changes. testes on sp1 - sp1.1 and sp2
the file opens flawless in autocad on mac. generated with ac on win.
see the screenrecording...
in parts i can reproduce this.
happens here too when there are pixels inside a pdf
the "angeld arms" are drawn by hand, whereas the lower pdf contains vector lines.
more strange are the grayed out pdf pages that you can see.
these came in from a pdf that contains several pages. i found no way to import them correctly...
this happens in different tools and things i am doing.
starting with selecting doors or windows that are placed in walls. after clicking on the elements it take 3-5 seconds that the spinning ball stops and the info in the oip gets visible.
editing path´s of extruded obects results in a sluggish interface where it takes some time that snapping point inside the path are found and snapped to.
moving a section viewport inside a sheet layer takes 2-3 second to get a redraw while the spinning ball is visible.
all geometry was buildt up in 2019, some parts converted from a 2018 version.
i stepped back to sp1.1 and the overall interface is much faster.
anyone else with this behauvior?
- 1
i´ll give that a try to get back to 1.1
thanks nic!
so - as i am having trouble with sp2, how can i go back to sp1.1?
sp1 is a not really helpful when working with multiple view panes.
i often get a spinball and vw does not react anymore when more than 2 panes are set up...
Just started playing with the new insert truss and insert connection tools.
Works great.
I moved the truss that is on top of the other one (connections also) and then i did an undo...
After that, the truss goes back to it´s original position, but the connection between both moves double the amount it was moved first...
see the screenrecording....
sp4 is very unstable for me. i guess i will go back to sp3.
getting more and more unexpected crashes also while updating references or saving and committing to project sharing.
also, when more drawings are opened i have problems with screen redraws and visual errors. in 2d plan things are where they are supposed to. in axonometric views everything flies around.
closing other drawings solves the problems.
things that didn´t happen in sp3
the tricks that rummelplatz wrote didn´t change anything.
Since i installed SP4 a few days ago, i experience more and more random crashes when doing something really normal like changing the view with keyboard shortcut or choosing a tool with keyboard shortcut or zooming with keyboard shortcut (i.e. command-2)
All crashes that i had the last days always occur after a keyboard shortcut...
Anyone else?
MacbookPro Mid2014, 16gbram, 2.8ghz i7, GeFroce GT750m, MacOS 10.12.5
Open Vectorworks and do not create a new project.
Choose "Irrigation Settings"
VW crashes immediately.
Tried it several times.
Strange behauviour that i came across
I was modeling an object while all profiles and preconstuctions have been in a group.
Each object has a solid filling and the fill color set to white.
Insides the group when open gl is turned on, everything looks good.
Exiting the group show that the group itself does not have a solid filling an the color of the 3d objects changes to a darker shading
Trying to change the attributes of the group does not do anything
Ungrouping the group does not change the color of the objects even the attribute palette shows the settings that have been made while modeling the objects...
Strange.
See the screencapture...
experienced some weird open gl transparency issues when using transparent renderworks materials
material is set to color mode and transparencayset to plain
regardless the amount of transparenca this occurs and doesn´t change upon switching to other graphic compatibility modes
see the screen recording
i have a group which contains polylines
when i try to pick the center of the polylines there is no snapping point
when i edit the group a can snap to the center of the arcs inside.
all object snappings turned on. does even not work with master snap turned off
did someone else find this already?
so i am not alone.
afraid too ,-)
It´s a rather small file that does not open in 2017
was created in 2016 and opens there seamlessly
vw2017 keeps telling that it is veryfying the file
force quit brings the attached error report.
can someone check this on another installation?
this is still the same behaviour with sp2...
Thank you Jim!
checked this right now with SP2 installed and the behaviour ist still the same...
i am nonlocalized .-)
yes, germany is correct, but we use the international version on all of our workstations.
i´ll check tomorow in the office if sp2 adresses these issues. right now it´s time for a glass of red wine .-)
when checking for updates vw tells me that it is up to date :-(
no sp2 for me...
VW19 SP2 dramatic slow down...
in Troubleshooting
Posted
Thx Tim!
