Thanks!
It is never a good idea to change something so basic and provide (i.e. thru they lame VW help?) an easy way to query the problem, if it was not for this forum I would still be searching their very dense (both definitions) help menu.
Jim
I talked with a tech.
The problem: usiing a 2010 file upped to a 2011 file one of the classes had "markers" set in the edit class dialog box and since there is not a "None" toggle I could not get it to stop drawing arrows!!!!!!!!!!!!
The solution: he said that I had to go to markers and select "custom" and make it "zero's" for angle and etc. This is a very unsatifactory solution please don't create dead ends like this. The reason given was "because ACAD import files can get messed up..........that's a sorry reason to frustrate me and not even give the simple toggle to fix it......All I want is "none"
At a minimum: in the help file give a reason for it and a fix it like listed above.
A radio button for "Zoom Line Thickness" in vectorworks pref. would be great - I am constantly toggling this back and forth esp. when I am using some heavy line wts.
I had & have this same issue - I could not zoom in too close or else all the lines disappeared...maddening... I talked with a
VecW Tech person
- I was using a 2009 .template file that was up-converted to 2010 when i started a new drawing - we determine that it was some-kind of upgrade bug. The fix - copy paste the elements from the problem file to a new 2010 drawing and the problem went away in the new file.
