bcd
3,484 -
Posts posted by bcd
AEC>Machine Design>3d Properties
AEC>Machine Design>Centroid
Model>Engineering Properties
Model>Volumetric Properties
For a part being designed using a particular Material the OIP should update to reflect the engineering properties
Multiple selected objects with various Materials applied should also show the total mass in the OIP
- Popular Post
- Popular Post
On 5/20/2019 at 3:32 PM, Benson Shaw said:What Pat said ^
Plus, if working with a string or chain dimension, right click any individual dimension within the chain, and in the context menu select "Edit Dimension". In the edit dialog, add or adjust text or values in the Leader, Trailer, or Notes fields (or any of the other fields). This action only affects the individual dimension.
If the chain is selected (identified as a Dimension object in OIP), any change to the Leader, Trailer, or Notes fields appends that new info to every dimension in the chain. This action would overwrite any previous edits to same field in individual dimensions in the chain.
-B
This is very useful too for those individual Leader Lines for the small dimensions in a chain.
- 5
If a fillet, shell etc. fails because the specified dimension is too large - why not offer the max dimension possible as an option first rather than a jarring beep and unhelpful help message?Then it becomes a series of guess,beep,guess,beep... guess,works, guess a bit bigger, beep, .... bit smaller ... .. beep 🙂
And in this case the order you click the walls for your L-join determines which wall abuts which
- 2
Currently PDF pages are unhelpfully imported stacked on top of each other with a small offset.
It would be much more helpful if they were brought in and auto-arranged in a grid - the width/height or spacing of which could be part of the import dialogue.
I believe this was requested years ago too.
- 2
On 2/6/2024 at 12:18 PM, Pat Stanford said:
I have a slightly different take on why there are different types of symbol folders. Perhaps if we offer enough theories, someone from VW will stop in and tell us which is closest to the truth 😉
Just yesterday I was praising the fluidity of the Resource Manager & how quickly and comprehensively the search is. (Although including misspellings in the search would be a welcome improvement even now)
I remember when you may as well gone to make a cup of tea anytime you wanted to search the old Resource Browser. I suspect the Folder structure was set up then as a way to try and optimize the horribly slow search.
- Popular Post
- Popular Post
A lot of cool modelling here.
I would also choose a different texture for the stone floor. It looks like cobbles that have been scaled up, resulting in the grout relatively too wide and the displacement too large. In a setting like this I would expect to also see an area rug.
I'm curious why we can see out one window but none of the others. Could it be to do with the reflectivity/ transparency settings of the glass texture?
...because a vision softly creeping...
- 1
Yes, the light is where it's at in a scene like this.
You will get most of the light from the fire - the candlelight will be very localized & there should be much more shadow where shadows would naturally fall.
On 2/8/2024 at 7:00 PM, Lance C said:
This still didn't work
I'm curious if you find a solution.
Are you also running Adobe Creative Cloud Content Manager?
ps @Lance C you may not know that the thumb is more an expression to the person helping you than to their suggestion. I would be giving @Pat Stanford a thumb up 👍 for his response and replying that his solution didn't fix the issue.
I'm also having a font problem
Skia is showing correctly in VW but exporting to PDF I lose the emboldened Skia and also Skia bold.
Here it is showing both in VW and Preview &/or Acrobat ( on the mac) I haven't tested yet on PC
As it says on the tin:
I'd like to lock the position of one object and have other objects constrained to it.
Create a Section Viewport of the model on another Design Layer,
Choose Display Flattened in the OIP
- 1
2 hours ago, Cristiano Alves said:
Third Question:
Another challenge is to perform an "Extrude" in a ramp shape on one of the parts.
How can I achieve this incline, considering the "Extrude" tool only has one measurement?
This is not as trivial as it first appears, because the true slope of the ramp is not perpendicular to the end profiles. The easiest way is in a Front View :
- Draw a rectangle for the u/s cross section and another for the d/s cross section offset by the correct distance
- Select both, Model>Multiple Extrude by the perpendicular distance between them both.
- 3
I think you're right - and sadly missing
And press the B key for x-ray mode
- 3
I hear you Tom, I just don't bother with the convert to guides step - but none of this should be needed.
- 2
The Rotate tool is deficient - probably because we're missing a Snap to Lever Arm setting.
If I want to rotate an object (rectangle in the example below) from a given point (A) about a given fulcrum (O) there is no way to restrict the rotation based on a given lever arm.
The current workaround is to first draw an arc - this shouldn't be necessary. It seems that this was the intention when the tool was designed, why else would the HUD display the length and angle before the second click but currently we only get the angle in the HUD before the third click - the length should be visible and lockable.
eg.
- 4
9 hours ago, Benson Shaw said:
I think best approach to drawing is extrudes.
100%
Select them all then
Landmark>Send to Surface before Cut&Paste in Place into the source data - they won't change the geometry of the Site Model but will allow it to add localized tessellation which should help with the issue you're seeing
- 1
Have you tried adding additional 3d loci to the source data per my earlier response?
Best way to make a simple "general note" that will update across all instances?
in General Discussion
Posted
This sounds like a job for the Title Block
You can add data on a per Sheet
Edit the Title Block Style
Sheet Data>Manage Sheet Data>Add a new field
Title Block>Edit Title Block Layout place some text and in the OIP convert it to Data Type>Link Value, Parameter>Sheet Data, your newly created field.
Then via the Title Block manager you can select which Sheet Layers you want to display this text and edit it to suit.
However, having the Title Block Manager speak to the Notes Database to enter that text would be the business.
