WhoCanDo
402 -
Posts posted by WhoCanDo
Sorry to let this slide for such a long time. I get busy spells.
When creating a worksheet and adding Database line and formula such as
=('Record Name'.'Field Name')
I would normally turn the database headers off.
After adding serveral database lines to the worksheet and then adding the records to the objects on the drawings you can "Recalculate" the database.
All objects on the drawing with records will list and the database lines that don't have records recorded on drawing objects are invisable (don't list).
These empty (invisable) lines are made visable when exporting to .dwg which is not correct. Only the visable line items should export.
When I have a worksheet that includes 20 database lines but only one record is used, the result shows a number of items on the drawing with different lengths & widths on different lines correctly.
After export the line items appear as well as the other 19 unused (normally hidden) database lines.
SP1 didn't allow metafile export and import to get around this but SP2 does. However this is not the solution to the problem.
If anyone else can emulate the problem then I can report it as a bug to VW.
Ozzie,
I have now downloaded a fresh update and realised that my previous download is only half the size of the new one so I must have somehow lost some during copying ???
Thanks for the suggestion.
I have used the same installation download on XP & Win'7 but on Win'7 the installer won't even run except for an hour-glass for a few seconds.
Has anyone else installed on Win'7 ?
Much appreciated ccroft. I'll try that.
Thanks.
I'm not totally clear on what you guys are arguing about or what you are actually saying (95017 ????) but has anyone answered my question yet?
All I am asking VW to do is pick the double line tool, show the setup window and then let me use the tool as normal.
I am guessing from above that you can't do this so utilising your expert VW skills instead of your expert arguing skills can someone give me a suggestion (without being rude).
Maybe this should not be a tool type?
This simple macro, which makes it easier for me to draw parallel lines throughout the day, works as a macro in Vectorscript Palettes but does not work properly as a tool.
1. I want the StrDialog question before the tool activates. Why in Vectorscript Palettes does the StrDialog activate first but as a tool it activates after the first point is selected?
2. Hovering over an object vertex and then moving away shows extension lines. In the Vectorscript Palettes if the mouse moves slightly off the extension line and then pick a point, the picked point is actually along the extension line (ie. correct). Why doesn't a tool work in the same way? Picking a point slightly away from the extension line with the tool actually picks the point under the cursor.
How can I resolve these problems?
procedure Parallel_Line_Tool;
var
Line_Separation : real;
begin
Line_Separation := GetDLSeparation;
Line_Separation := Str2Num (StrDialog ('Spacing?',Num2StrF (Line_Separation)));
SetDLOptions (0);
SetDLSeparation (Line_Separation);
CallTool (-216);
end;
run (Parallel_Line_Tool);
Kool Aid,
I have AutoCad 2006 and it opens as many files as I have tried with only one instance of the program running.
You can batch print because you have something other than the Fundementals version that I have. I cannot justify a version change at this time.
Ray,
Each tile has a class number. Each tile that is similar has the same class number and each tile that is different has an individual number.
I draw on layers so class visablity is not currently in use.
I have tried Viewports but the only reasonable way of detailing the tiles is to copy and past them to another drawing.
Duplicating any tile in the same drawing will double the data (ie weight, qty, etc) attached to the panel so detailing the panel in the same drawing does not seem feasible.
I would normally only have two drawings open at a time during this process since I will save the detail sheet as another drawing name before pasting another tile for dimensioning.
Only after all the tiles a detailled will I open the detail sheets to print them all.
Do you have a different method in mind?
I draw flooring tiles (to put it simply) that fit around machinery and structural steel. Each tile is dimensioned individually on a separate sheet and needs to be printed.
Worksheets still export expanded (ie. hidden & unused lines) in VW2010 SP2 !
I can't be the only one exporting worksheets can I ?
At least metafiles are now working in SP2.
If you read the licence agreement in VW2010, section 1.4 (b) & © you may find a solution. On a network two VW's with the same VW licence number won't work at the same time but will work one at a time.
You must comply with the licence agreement.
After all this time with no responses I would guess that no one else has the problem or
does anyone export their worksheets that include database line items?
Do the quick keys ctrl-F6 or ctrl-Tab work?
I'm like you so check out the bottom post of the following link:
I created this as a tool and it works well.
Some of my fills weren't printing until I switch "Print patterns at on screen resolution" on in the print menu.
VW seems to have changed in VW2010
I've already let them know that the 2010 help is called 2009 if there listening.
I would like to see VW catch up with AutoCad, Adobe and other software that opens many more files at any one time.
I often want to print 50 to 60 drawings at one time and at the moment I have to count in eights to acheive this.
If it's a difficult thing for VW to do then opening 10 at a time would be easier to count than eight.
I find that scale objects works best after selecting all and changing symbol to group since symbols won't scale and many drawings I receive have symbol components.
What are obsolete functions if they still work.
eg. DoubLines is obsolete after VW12.5 but it still works in VW2010
If VW takes the time to mark a function obsolete then why don't they add a cross reference to the replacement function?
eg. What is the replacement function for DoubLine?
This is what I have so far if anyone else wants it..
procedure Layer_Visability;
label 1, 2;
const
DialogWidth = 300;
DialogTextBoxHeight = 30;
var
WorkLayer : string;
i, Event, ItemID, LayerCount : integer;
sx1, sy1, sx2, sy2 : real;
dx1, dy1, dx2, dy2 : real;
h : handle;
LayerName : array [1..100] of string;
begin
{ Record all layer names }
LayerCount := NumLayers;
h := FLayer;
LayerName [LayerCount] := GetLName (h);
for i := LayerCount -1 downto 1 do
begin
h := NextLayer (h);
LayerName := GetLName (h);
end;
{ Create Dialog }
GetScreen (sx1, sy1, sx2, sy2);
dx1 := sx2 / 2 - DialogWidth / 2;
dy1 := sy2 / 2 - (LayerCount / 2 + 5) * DialogTextBoxHeight;
dx2 := dx1 + DialogWidth;
dy2 := sy2 / 2 + (LayerCount / 2) * DialogTextBoxHeight;
if (dy1 < 0) then { if the dialog box is too long }
Goto 1;
{ Begin Dialog }
BeginDialog (1, 1, dx1, dy1, dx2, dy2);
AddButton ('OK', 1, 1, (dx2 - dx1) / 2 - 102, dy2 - dy1 - 45, (dx2 - dx1) / 2 - 34, dy2 - dy1 - 15);
AddButton ('Cancel', 2, 1, (dx2 - dx1) / 2 + 34, dy2 - dy1 - 45, (dx2 - dx1) / 2 + 102, dy2 - dy1 - 15);
AddField ('LAYER VISABILITY', 3, 1, (dx2 - dx1) / 2 - 70, DialogTextBoxHeight, (dx2 - dx1) / 2 + 70, DialogTextBoxHeight * 2);
AddField ('Choose layers to be unsnapable.', 4, 1, 20, DialogTextBoxHeight * 2, DialogWidth - 20, DialogTextBoxHeight * 3);
ItemID := 4;
for i := 1 to LayerCount do
begin
ItemID := ItemID + 1;
AddButton (LayerName , ItemID, 2, 40, DialogTextBoxHeight * (ItemID - 2), DialogWidth - 20, DialogTextBoxHeight * (ItemID - 1));
end;
EndDialog;
{ Start Dialog }
GetDialog (1);
repeat
DialogEvent (Event);
if (Event > 4) then
SetItem (Event, not (ItemSel (Event)));
until (Event = 1) or (Event = 2); { OK or Cancel }
WorkLayer := GetLName (Actlayer);
{ Change selected events }
if (Event = 1) then { OK }
begin
for i := 5 to LayerCount + 4 do
if (ItemSel (i) = True) then
begin
Layer (LayerName [i - 4]);
DoMenuTextByName ('Standard Views', 2);
end
else
begin
DoMenuTextByName ('Standard Views', 1);
end
end;
{ End Dialog }
ClrDialog;
{ Return to working layer }
Layer (WorkLayer);
ReDrawAll;
Goto 2;
1:
AlertCritical ('Too many layers.', 'A second column may be necessary.');
2:
end;
run (Layer_Visability);
Thanks Ray, but I want multiple layers unpickable so a macro will be the best for me instead of going to each layer and changing it to top view.
Sorry, this didn't work the first time but it does now:
DoMenuTextByName ('Standard Views',2);
Thanks
Great, I didn't think of that.
So after a quick look though the VS help I cannont find a procedure to change layer current view. Is there a command I can write a macro with?
Thanks Mike,
I do mean unsnappable.
My current approach to this is to make scale of the layers I want to see but not snap to 0.0001 greater so they don't appear different but dissables snapping.
This means I can work on and snap to the other 4 or 5 layers without accidently picking up the snap points on the support layers.
I would like to see greyed made unpickable or another layer option to do this.
I am often workings on multiple layers and want to see support or design layers but not be able to pick things on them.
One example is when I have a floor outline that I wish to manufacture in smaller segments. I need to know where the support structure is and work on the other layers without selecting objects on the support layer.
How do you free rotate an object with Vectorscript
in Vectorscript
Posted
I want to create an object:
repeat
if (MouseDown(x1, y1)) then
begin
moveto(x1, y1);
x2 := x1 + 580;
y2 := y1;
closepoly;
poly (30,#90,x2,#0,30,#-90);
h := lnewobj;
end;
until (h <> Nil);
and after h := lnewobj; I want to pick the object and free rotate it with the mouse around x1,y1 until I pick a second point with the mouse.
I've tried
repeat
getmouse (x3, y3);
rotatepoint (x1, y1, AngleOfRotation);
redraw;
until (MouseDown (x3, y3));
but I think I am on the wrong track.
Any suggestions please?
