SpacesfromList.vwx 1.0.5
   (2 reviews)
3 Screenshots
About This File
This Marionette Script creates multiple space objects from worksheet data.
A very nice and time saving Marionette script to automate a routine peace of work.
Please consider, that the the script takes the area column and calculate the square with that. If you have a language settings with comma instead of points for decimal seperator, the calculation will fail. Use points as decimal character or eliminate decimal places in your list
Edited by DomC
What's New in Version 1.0.1   See changelog
Released
Converted to 2018
Spaces from List v2018.vwx
1. Fixed SetRecordField Nodes
2. Converted to 2019
3. Use a Stile for Space Input instead of a Wrapper Geometry
4. Additional Example with fixed with
  • Like 9
User Feedback
Patrick Fritsch
   0 of 3 members found this review helpful 0 / 3 members
Hi Dom, could really use this but does not seem to work in VW 2021? I upload my text file but get no spaces returned? Thanks,
Response from the author:
I don't know which Textfile you use and which script (Version 2018, 2019 or 1.0.2?). The Message says, that you try to take the square route of something that is not a number or which is 0.
The Script also works with 2021. If you connect a random textfile with random settings of the data mapping. How the script should react in your opinion except an error message?
Link to review
tca
· Edited by tca
   0 of 2 members found this review helpful 0 / 2 members
I get an error (see screenshot) when trying to run the script.. any help??
The Spaces will be created with a size related to an area in your List. Possible maloperation could be you define a column with no numeric strings. Also if your numbers uses comma as a decimal-seperator instead of a point. The Script can't convert them into a number and report that as an error message. It is quite common, software can not handle  any kind of maloperation and fix automatically wrong inputs.
In newer Versions the Script uses a custom version of the Float- Node. It tries to convert without error. If an issue occurs it returns just 4 qm instead of an error message. Don't know which is better.
Link to review
