Circular Growing and Filling 1.0.1
   (3 reviews)
3 Screenshots
About This File
During my last Marionette-Project, I produced some simple geometry nodes. Which maybe can be useful to can make geometrical constructions instead of mathematical (trigonometry) calculations.
The Nodes:
"Perpendicular from Point to Line", "Parallel from Line through Point", "Circle-Circle Intersection", "Line-Circle Intersection", "Line-Line Intersection", "2 Circle Middleline" and some more.
Also the more Complicated Nodes "Circle tangent to 2 Circle", "Point or Circle tangent to 3 Circles"
What's New in Version 1.0.1   See changelog
Released
Update the Growing Example (replaced Symbol Scale Node with The Default Node)
This Script Creates a Grid, Randomize the Grid als let grow circles on the Point one by one. If it have contact with another "circle" it stop growing both Circles.
What maybe could be missed:
1. Choosing different Symbols (could combine with filling area with Symbol Example)
2. Filling White Area with further Objects
Screenshot it with a big Randomize Grid Value and with a negative Offset (overlapping of Circles)
  • Like 6
  • Dislike 1
User Feedback
rDesign
   1 of 1 member found this review helpful 1 / 1 member
Great set of geometry nodes, perfect for creating a circle tangent to three other circles. Thanks!
  • Like 1
Link to review
PVA - Jim
I could watch those circles dance all day.
  • Like 1
Link to review
lgoodkind
· Edited by lgoodkind
This could be a very useful script for generating planting plans for complex natural systems like native meadows where drawing planting plans is and exercise in circle insanity.  I however am not able to get it anywhere close to being useful for this purpose.  Attached is the file with a folder containing very simple plant objects in it.  The script does not pack the symbols like the simple procedural example, Is this intentional?  Perhaps I've got something wrong? I confess the math is over my head and beyond what I have time for.
CircularFilling v2021.vwx
Response from the author:
Hi
If you use the default "Scale Symbol 3D", the original from one of the scripts does not work in newer Versions anymore.Then it will work more as you expected I think but still not does what you want.
In your script, you randomly take a symbol and scale ist. So you take a small tree and scale it to the desired diameter. You should first generate your diameters and then pull the matching symbol I think. The script does not work on fixed diameters. Also in nature, your trees maybe do not follow the rule of that fixed diameters 🙂
The Script is bases on random diameters, so it will not work to have as a result fixed diameters.
  • Like 1
Link to review
