holstarc Posted May 30, 2002 Share Posted May 30, 2002 i have been trying to render an imported 3d model, but am having no luck...It wil render in an orthogonal mode but not in perspective, it simply renders white...I can still select the objects, I just can't see them...any help. I am running VW9.5.1/RW 9 Thanks Quote Link to comment
Matthew Giampapa Posted May 30, 2002 Share Posted May 30, 2002 The perspective mode has a virtual camera that has to be within a certain distance of the objects you are rendering. If you are extremely far out, the distance to the camera will exceed what we can measure using an integer value. This will cause the problem you describe. Try zooming in a bit closer and your rendering should show up. Matthew GiampapaNNA Technical Support Quote Link to comment
holstarc Posted May 30, 2002 Author Share Posted May 30, 2002 Thanks for the advice, but I've tried that. i have tried creating views several ways, one of those being the set view command, not far from the object, 20ft or so and the building still won't show up. This file has been imported from Form-Z and the surfaces are triangulated, will this cause these problems...if so any way to prevent this in the importing command. Quote Link to comment
holstarc Posted May 30, 2002 Author Share Posted May 30, 2002 some more info...The model will render in the hidden line/dash line and shaded solids mode, but it won't render in either the open GL or any of the renderworks modes. Quote Link to comment
Matthew Giampapa Posted May 30, 2002 Share Posted May 30, 2002 Holstarc, I don't know any other issues that this could be off the top of my head. Can you email set up with this problem to tech@nemetschek.net? Actually the line based renders and the OpenGL/RenderWorks renderers work off of two different systems. So I'm not surprised that they are both showing the problem when the others aren't. Matthew GiampapaNNA Technical Support Quote Link to comment
holstarc Posted May 30, 2002 Author Share Posted May 30, 2002 thanks Matt...i will email the file right away. Kevin Quote Link to comment
Matthew Giampapa Posted June 3, 2002 Share Posted June 3, 2002 O.K., I think we found a bug in the rendering process for perspective mode in this situation. It's been corrected for the next release, but in the mean time, just change your layer options to "Active Only" and this file should render correctly. Matthew GiampapaNNA Technical Support Quote Link to comment
