Peter Eichel Posted April 7, 2006 Share Posted April 7, 2006 I know you cannot use hybrid windows when creating these roof components, however, if you drag a hybrid window onto a roof from the resource browser, it works, if you make it active, it doesn't work. If your making a skylight, it will cut a hole in the roof but won't insert the window. When I drag the same hybrid window into an open space with the intention of rotating it and then moving it into the roof cutout, I get the message "hybrid objects can only be rotated in the Z axis", grrr!!!. Can someone please give me step by step instructions on how to create a window that works from a hybrid. Thank you. Quote Link to comment
Peter Eichel Posted April 8, 2006 Author Share Posted April 8, 2006 I did a search and found the answer. Thanks Robert. Quote Link to comment
billtheia Posted September 9, 2008 Share Posted September 9, 2008 Peter, did you find a way to use window PIOs for skylights? I'm trying now and can't get anything to work. Quote Link to comment
Yancka Posted September 10, 2008 Share Posted September 10, 2008 Bill, the answer is that for skylights you must use symbols that are 3D symbols. That means they contain only 3D geometry. Quote Link to comment
