ron Posted March 29, 2006 Share Posted March 29, 2006 When I turn off "plan detail" for windows and doors the wall lines are showing through the trim. Is there some class or lineweight setting I need to adjust to make this look right? Currently my wall/door classes are set to the same width as the walls. Quote Link to comment
Jeffe' Posted March 29, 2006 Share Posted March 29, 2006 You can set the class to one of the "styles" under Window preferences>View>Special Classes, then turn them off. You can set them to have different rendering properties using this as well. BTW: the pic you linked to doesnt work. [ 03-29-2006, 05:30 PM: Message edited by: Jeffe' ] Quote Link to comment
ron Posted March 29, 2006 Author Share Posted March 29, 2006 Here's the photo. The object I'm guessing is to get the white lines to match the width of the wall lines thus hiding them. I don't know where the white lines get there properties from though. Any suggestions? Quote Link to comment
