rollingroots Posted March 8, 2006 Share Posted March 8, 2006 I am trying to set my stairs by layers so that I can see the top of the stairs on my second floor, but I keep getting zero regardless of the two different z values for the two different layers. I have created new files, gone through the model setup and placed stairs and it works fine. It is a bug with the particular file I am working on. Any help? Quote Link to comment
D Wood Posted March 8, 2006 Share Posted March 8, 2006 Welcome to the Vectorworks forum. It would help if you could say what computer you use, and what operating system and version of VectorWorks you are using. The stair tool changed between v11 and v12, so the answer will depend on which version you use. Once you set up a signature you can reuse it each posting. Regards David W Auckland NZ G5 iMac, 1.5Gb RAM, OS 10.4.5 VWA+R 11.5 Epson Stylus Color 1160, HP Designjet 110plus nr Quote Link to comment
rollingroots Posted March 8, 2006 Author Share Posted March 8, 2006 Thanks David. I solved the problem by creating a new file and transfering the data. I don't like this solution as it requires a bit of time to set up the new file. I am on a p4 pc 1.25 g ram win xp vwa 12.0.1 Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted March 8, 2006 Vectorworks, Inc Employee Share Posted March 8, 2006 rollingroots, it would be helpful if you could send your old file (that wouldn't work properly) to bugsubmit@nemetschek.net along with a description of the bug. Thanks! Quote Link to comment
