I am new to Vectorworks. I have imported new plant data into the plant list and have tried to create a plant database using the "Create Vectorworks Plant Database" command in the Vectorworks Plants plugin. Every time I use that command, regardless of which plants or how many plants I get an error saying ""XXX.txt" could not be created on this disk. Use a different name, make more room on the disk, unlock it or use a different disk." I have tried different names including the standard name "Plant Database" to no avail. I also have saved numerous other files using export and save a copy commands etc and have no problem. The disk has plenty of space. It seems to me I should be able to save a catalog based upon the manual and other discussion.
Curtwitt
Any help on this? Thanks in advance.
1 answer to this question
