Remove choices from popup in Dialog
DomC
Hello
Would be great if anybody could help me. At the end result I want to be able to exchange a popup's choices. What I am trying to do is, that I delete the items with vs.RemoveChoice()
and build it new with a loop through my choices. I think I make something wrong by indexing with "AddChoice" or "RemoveChoice" just remove the string not shorten the Choice Numbers.
My script:
choices1 = ['choice1', 'choice2', 'choice3', 'choice4']
choices2 = ['choiceA', 'choiceB']
def CreateMyDialog():
	vs.dialogid = vs.CreateLayout('Dialog Name', 0, 'OK', 'Cancel')
	dialogID = vs.dialogid
	vs.CreateStaticText(dialogID, 10, 'Popup', 60 )
	vs.CreatePullDownMenu(dialogID, 11, 40)
	vs.CreateCheckBox(dialogID, 12, 'Change Popup')
	vs.SetFirstLayoutItem(dialogID, 10)
	vs.SetBelowItem(dialogID, 10, 11, 0, 1)
	vs.SetBelowItem(dialogID, 11, 12, 0, 1)
	return vs.RunLayoutDialogN(dialogID, Dialog_Handler, 0)
def Dialog_Handler(item, data):
	if item == 12255:  # enter Dialog 12255  -> 12256 exit dialog
		for i in range(len(choices1)):
			vs.AddChoice(dialogID, 11, choices1[i], i)
	if item == 12: #checkbox
		if data: #checkbox True
			num_choices = vs.GetChoiceCount(dialogID, 11)
			for i in range(num_choices):
				vs.RemoveChoice(dialogID, 11, i)
			for i in range(len(choices2)):
				vs.AddChoice(dialogID, 11, choices2[i], i)
		if not data: #checkbox False
result = CreateMyDialog()
Hello
Solved by searching the Forum. Seems we need backward indexing to delete the choices. Here the working popup Dialog.
		for i in range(num_choices, -1, -1):
Edited by DomC
