  • 1
Fix for Hidden Line viewport render bug 2022
Vectorhead
I was having an issue with extrudes in hidden line renders as many others probably are also having when creating an axonometric screen viewport. Not a problem when using the clip cube to create viewport only when using screen view. Many extrudes would not show up correctly as solids in the hidden line render mode. Having spent time trying different options I found a solution as a work around. Changing the render mode in the OIP for the extrudes from "Surface UV" (default) to "Plane" the render would show the extrudes as solids.
Edited by Vectorhead
  • Like 3
0 answers to this question
There have been no answers to this question yet
