I have a large working file in 2021 that I've converted to 2022. Upon conversion the hatch scales are visually about 100 times smaller (but the hatch scale of the VP is the same as the 2021 drawing) this is happening in all the viewports and across several files, making publishing a nightmare.
There is also slow response and sometimes an inability for the scale to update if I try to change it.
I have also been noticing a slow response when I select an object and its information to appear in the object info. Restarting VW will help for a while but the issue will return slowing down the workflow...
Is this a known bug with 2022? and is there any solutions? thanks.
JAMZ21
Has anyone experienced the following?
0 answers to this question
