Seena Hassouna Posted November 23, 2004 Share Posted November 23, 2004 That was my first thought too. I am in Top/Plan. With the windows, when I first look at them in top/plan, I see them. then when I go to right isometric for instance, they disapear. I select the wall, give it no fill and the windows reapear. Then If I fill it back in all is well. Apparently it's only a temporary fix. Thanks, seena Quote Link to comment
Kevin Posted November 23, 2004 Share Posted November 23, 2004 It is possible to set a window or door onto a wall and not have it insert. It will appear in plan view but will not appear in isometric view as it is not part of the wall. Be sure that the object inserts into the wall. When properly inserted, the PIO will read "Door in Wall". If the door is not inserted, it will simply read "Door". Quote Link to comment
Seena Hassouna Posted November 23, 2004 Author Share Posted November 23, 2004 Yup, Thanks. I have had that trouble before but not this time. They all say door or window in wall. Thanks anyway, S Quote Link to comment
Seena Hassouna Posted November 24, 2004 Author Share Posted November 24, 2004 So, I am having trouble with windows and doors. My doors are spontaneously shutting, i.e. the door is closed in the plan. If I fiddle with the options it opens again, but I never had it set to close. Also, I went to my elevation viewports and my windows had all disappeared. I went into the design layer and had to select the walls, turn off their white fill and the windows reapaer. Then turned the fill back on and everything was fine. Now, I open the file this morning and the doors are closed again and some of the windows are gone. I have been cutting 3-D sections of the model. Does this mess up the original model? This is very worrysome. Please help. thanks, seena Quote Link to comment
Kristen Posted November 24, 2004 Share Posted November 24, 2004 My first suggestion is to go to the "view" menu. Are you in "Top" view, or in "Top/plan" view? I think that when you cut a 3D section, your model goes to "Top" view. But you need to be in "Top/Plan" view for your 2D stuff like door swings to be visible. Quote Link to comment
