Reverse Node for Vector to angle?
Hi,
I have to move some objects in an angle but i only got vectors, so i dont know how to calculate a vector out of an angle and there is only "vector to angle" node.
MAybe someone has a reverse node or knows how this goes better with different nodes.
I have a list of path extruded rectangles along lines, which generated out of a polyline (red).
But the profile which is extruded allways is "placed" in the middle (center of bounding box) of my path extrude.
But I need this extrudes BEHIND or INFRONT the line (The Profil has to be extruded in the edge of my ).
So i thought i can read out a list of angles of the lines and use the "MOVE" node to move the Boxes half height and half width.
But the node needs a vector not an angle.
BR KC
Extrusionsbauteil_Version_2.vwx
Edited by KingChaos
Hello,
there is a VS Function that converts an angle into a vector. You can look it up here.
With that Function you can write your own Marionette Node. In Python it could look something like this:
@Marionette.NodeDefinition
class Params(metaclass = Marionette.OrderedClass):
#APPEARANCE
	#Name
	this = Marionette.Node( 'Angle to Vector' )
	this.SetDescription( 'Converts an angle in degrees to a 2D vector' )
	#Input Ports
	nAngle = Marionette.PortIn(0)
	nAngle.SetDescription( 'an angle in degrees' )
	nLength = Marionette.PortIn(1)
	nLength.SetDescription( 'the length of the output vector' )
	#OIP Controls
	#Output Ports
	v = Marionette.PortOut()
	v.SetDescription( 'a 2D vector' )
#BEHAVIOR
def RunNode(self):
	#inputs
	nAngle = self.Params.nAngle.value
	nLength = self.Params.nLength.value
	#script
	v = vs.Ang2Vec(nAngle, nLength)
	#outputs
	self.Params.v.value = v
But, as shown in the example below, in some cases the VS function returns realy small numbers instead of zeros. So i would recommend to round the returned values to a reasonable length.
Edited by Letti R
