Mentor Haziri Posted April 8, 2005 Share Posted April 8, 2005 I'm trying to draw roads, and I have to many junction. I send the road to the DTM a use road tee, when I use send to the surface it is not working properly. Is any command that I can join roads from other direction and make junction with proper radius. I'm using VW 11.5. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted April 8, 2005 Vectorworks, Inc Employee Share Posted April 8, 2005 Right now, the roadway-tee is the only method we have for detail joining of roads. How do you mean it is not working properly with Send to Surface? (Make sure you are in a 3D view when using the Send to Surface command). Quote Link to comment
Mentor Haziri Posted April 8, 2005 Author Share Posted April 8, 2005 Yes I try it in 3D view, I select the tee,previously i put into the same class and layers with terrain and road tee, but nothing same massage vector script error. Evend the road previosly made with arc polyline, in te top view I can see the station in proper elevation but in 3D the road is not layed in the terrain. Thank you mentori Quote Link to comment
