Kevin Posted October 21, 2002 Share Posted October 21, 2002 I have my architect's stamp as an image on my common sheet. It has a unique class setting of Architect Stamp. For preliminary drawings this class is set to invisible. When I am ready to print final drawings, I then turn this class to visible so that all final drawings will bear my stamp. The problem is that I must go to each and every saved sheet and change the Architect Stamp class to visible. Is there a way to change the class in all saved sheets at once instead of one at a time? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted October 21, 2002 Vectorworks, Inc Employee Share Posted October 21, 2002 Set your architect's stamp class to the "Don't save" status in all your sheets. Once. Then just make the class visible when you're ready to issue, or invisible the rest of the time. The sheets will ignore this class when it is set to "don't save". HTH Quote Link to comment
Kevin Posted October 23, 2002 Author Share Posted October 23, 2002 Robert; Thank you for your timely help. I will give it a try. Quote Link to comment
