AN Design Posted September 30, 2002 Share Posted September 30, 2002 Currently using VWA 9.5.1 on Mac OS 9.2 w/ carbon library 1.4 w Hp 500ps and all is fine. Tried updating carb to 1.5 & hp stopped working. Since VWA 10 requires carb 1.5 or higher,if I purchased 10 I would be unable to print to the HP. Is this correct? Also would like to know if a trial or demo version of VWA10 is available, before I invest the bucks in a version that may not work, without the hassle of another 30 day money back statement. Quote Link to comment
Guest Posted September 30, 2002 Share Posted September 30, 2002 You should use Carbon Lib 1.6. Keep 1.4 on hand in case you need to revert back to it. Finding where to download 1.4 is a bit tricky on the apple website. When you say it doesn't work when printing, what happens? Are you using the HP rip software, or are you using MacPlot? If you are not using MacPlot, you may want to consider that. The HP Rip software is very old and has never been updated. We've seen MacPlot to address the problems associated with the HP Rip software and it is what we reccomend. As for a demo version - you need to contact sales, or your local distributor for more information. [ 09-30-2002, 09:34 AM: Message edited by: Katie ] Quote Link to comment
AN Design Posted October 4, 2002 Author Share Posted October 4, 2002 Katie Printer does not respond, system does not recognize it is there Quote Link to comment
Guest Posted October 5, 2002 Share Posted October 5, 2002 Try to setup the printer driver/ppd file. Update to CL 1.6 Are you using HP rip software or MacPlot? You will need to contact sales about demo information. Quote Link to comment
