ErichR Posted July 31, 2002 Share Posted July 31, 2002 All of a sudden the callout tool (behind the line tool) gives only the arrow and not the note. An error message appears: "Object creation failed due to invalid parameter(s). Please use different parameter(s)!" This message appears upon duplicating an existing note, when creating a new one, when moving an existing note, or when trying to modifying an existing note. This happenes in all previously created drawings and in newly-created ones. I've tried reopening VWA. Same problem. By the way, what happened to the old (and useful) note leader tool? VWA 9.5.1Win98 Quote Link to comment
Guest Posted July 31, 2002 Share Posted July 31, 2002 The leader line tool is a secret. It's hidden to send you on a voyage to find it. Actually it's in the program, you just have to add it to the workspace via the workspace editor. If you go intot he workspace editor, select the Tools tab, 2d tool and drag it from the left side to the palette and tool you want it to be with on the right side. Quote Link to comment
ErichR Posted July 31, 2002 Author Share Posted July 31, 2002 This is good news, but what about all of the disappearing callout notes? This is a MAJOR problem, affecting notes on many different drawings. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted July 31, 2002 Vectorworks, Inc Employee Share Posted July 31, 2002 Erich, the callout notes are not regenerating because they have a parameter value that is causing them to fail. If you send me the file (to randerson@nemetschek.net) I will look at the file and determine which setting is causing the problem. If possible, send me a file with only one object in it -- an "invisible" callout. This will make diagnosing the problem easier. Quote Link to comment
ErichR Posted August 1, 2002 Author Share Posted August 1, 2002 Robert responded right away after I sent him a file. He suggested trashing the preferences file. Sure enough, the text size in VW had somehow defaulted to 0, causing the callout tool to be non-functional. Case closed. Quote Link to comment
Guest Posted August 1, 2002 Share Posted August 1, 2002 For future reference, I have seen this happen two other times to someone that had referencing in the file. The text was fine until a ref. was added. When I tried the customers problem in VW 9.5.1, it seemed to work. Since then I haven't tried it in VW 9.5.2 ... I totally forgot about this problem when you first asked the question. Sorry for not thinking of that. Quote Link to comment
