MikeN Posted April 10, 2002 Share Posted April 10, 2002 Is it possible to batch export VW files as you would use the 'Print Sheets' command? Quote Link to comment
Kevin Posted April 10, 2002 Share Posted April 10, 2002 I don't know about batch exporting, but could you tell me what the "Print Sheets" command is? This sounds interesting. Quote Link to comment
aersloat Posted April 11, 2002 Share Posted April 11, 2002 You might be able to batch export using an AppleScript calling a VectorScript which has the "DoMenuTextByName" procedure... I really don't know. The easiest way might be to use QuicKeys to call the dialogs, etc. The print sheets command will print the sheets you have set up one by one. Basically it just activates a sheet and then calls up the print dialog. Quote Link to comment
Kevin Posted April 11, 2002 Share Posted April 11, 2002 Austin; Thanks for the info. Where does one find this "Print Sheets" command. I have looked everywhere. I am using VW 8.5.2 on a Mac. Quote Link to comment
Guest Posted April 12, 2002 Share Posted April 12, 2002 quote: Originally posted by mnelson: Is it possible to batch export VW files as you would use the 'Print Sheets' command? If you mean batch DXF export, it's on our wish list. The AppleScript approach might work. Quote Link to comment
Matthew Giampapa Posted April 16, 2002 Share Posted April 16, 2002 quote: Originally posted by Kevin: Austin;Thanks for the info. Where does one find this "Print Sheets" command. I have looked everywhere. I am using VW 8.5.2 on a Mac. This command is only in VectorWorks 9 Architect, sorry. Matthew GiampapaNNA Technical Support Quote Link to comment
MikeN Posted April 17, 2002 Author Share Posted April 17, 2002 When you say batch DXF export, I hope you mean to include batch DWG export as well. Quote Link to comment
