SimA 1 Posted February 28 Hello everyone my marionette generates 3d points and puts them in a list. I convert the points into a 3d polygon. I would now like to change the direction to end-start. ideally, the list is sorted first (z-a) and then the polygon is generated. can you help me? Thank you Quote Share this post Link to post
AlHanson 11 Posted February 28 There's a "Reverse List" node that you can attach between your point list and the 3D poly node that should give you what you're looking for. 1 Quote Share this post Link to post
SimA 1 Posted March 2 Hello AlHanson Yes, I think the Idde is good. maybe you look at the file. I don't want the red lines. I want a connection from brown to green (blue). the colors are used for explanation. I need the path. Do you have any idea? Thank you! Nurbs Netzt.vwx Quote Share this post Link to post
