bonose Posted February 13, 2002 Share Posted February 13, 2002 After initiating a project with VA Setup Assistant, I like to revise my set/sheet titles to conform to our sheet numbering system (i.e. ?Floor Plan-1 changes to A1.0 Floor Plan). The problem is that this negates the use of VA Task Manager, which apparently relates only to the initial sheet names established by VA Setup Assistant. When I query VA Task manager, there are no sheets listed. Does any one know a work around for this situation? Thanks Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted February 13, 2002 Vectorworks, Inc Employee Share Posted February 13, 2002 You can't do this at the present time. Be aware that 'Floor Plan-1' is only the system sheet name (i.e. the name shown in the Sheets popup). It is not the name printed on the sheet. Printed sheet names and numbers are whatever you want them to be and are easily established (and changed whenever you wish) using the Issue Manager command. Quote Link to comment
bonose Posted February 13, 2002 Author Share Posted February 13, 2002 Robert, thanks for the reply. I'm aware of the Issue Manager's attributes, but wish I could change the names to something more familiar in the Sheet Pop Up and streamline the selection process by a few milliseconds. Quote Link to comment
