Vectorworks, Inc Employee Robert Anderson Posted September 14, 2001 Vectorworks, Inc Employee Share Posted September 14, 2001 There is a parameter on the door object called Wall Line Scale that will (if set to less than 1) will reduce the line weight of the door from that of the wall. You can set the default setting of this parameter to any value you like by using the Create Custom Object... command. HTH. Quote Link to comment
MikeN Posted September 15, 2001 Author Share Posted September 15, 2001 What architect in their right mind draws the lineweight of a door the same as the lineweight of the wall its associated with? The VW Arch 9 door plug-in defaults to the same lineweight as the wall. This is one of the many riduculous defaults that needs to be changed ASAP! Why default symbol insertion to 3D? I have no need for a 3D sink faucet in construction drawings? Did NNA even consult with an architect when developing VW Arch 9? Quote Link to comment
