n ironside Posted August 31, 2001 Share Posted August 31, 2001 VW9 has eliminated the leader line tool and replaced it with what? The callout tool doesn't seem to be capable of the same function. I select the callout tool, change the object bubble setting to none, select solid arrow in the marker option, delete the word "Text" from the note box....very time comsuming, and I still am not getting a two part leader line with an arrow head. Is there an obvious way that i am missing to type a note and draw and leader line without having to go thru this as yet unsuccessful process? Quote Link to comment
doug shaffer Posted August 31, 2001 Share Posted August 31, 2001 The leader line tool is there, it's just hiding. I added it using the workspace editor. It is included with the '2D tools'. Good luck. ------------------ d. s h a f f e r a r c h i t e c t Quote Link to comment
n ironside Posted August 31, 2001 Author Share Posted August 31, 2001 thanks doug....seems there is a lot of relearning to do with VW9. I have been using this software since MiniCad 4, but this release has me spooked Now to go try your solution! Quote Link to comment
