Renderworks 9 and Roof Faces
Anyone found out how to render roofs created by using the Roof Face tool in Renderworks9. I'm using it with VW Architect9 mac version. Works ok with the other objects including roofs from roof tool (from polygons walls etc.)
[This message has been edited by Jonathan L (edited 06-15-2001).]
  • 1 month later...
I have founfd the only way to make roofs of more complicated forms that can be rendered [that i would normally make w/ the roof face tool] is to use the roof tool to establish the basic parameters of the roof, assign the textures, and then UNGROUP the resulting roof object into roof faces. These roof faces can later be edited thru the primitives and the texure mappings can also be edited at any time. It's a bit of a hassle to build things this way if they have any complexity but it does work fine.
