I'm using Architect and VW-8.5.2 and I discovered that some of the Marvin windows I'd used recently from the Object Library that came w/ Architect are no longer editable. Instead of appearing in the info pallette as a complex window [as it originally had] w/ all the many fields to edit for size,frame, mullions, etc.it appears as a "CUSTOM OBJECT in wall" and all I can edit is the position, height, and flip - in fact none of the other fields even appear. When I try to get another of the same window from the browser it has all of the fields and is editable. What gives?
The only thing I can think of is that i had originallly created the document in 8.5.1 then updated it when I received Architect [icluding replacing some earlier windows with the new Marvins] and then later opened it up and modified it in 8.5.2. I had also made some modifications to the Marvins upon use - just adding some mullions.
I'd really hate to have to replace all these window objects again.
