jdouglas Posted February 16, 2001 Share Posted February 16, 2001 I used VA assistant to setup a new job. Everything seems to work fine. The only problem I have is when I draw foundation walls on the foundation mod layer. The walls are grayed out and I can't select them to modify of delete. The z values are set properly and the walls display fine in perspective view, other that the grayed out problem. Quote Link to comment
rcarch Posted February 16, 2001 Share Posted February 16, 2001 check the layer and class settings for the walls you are drawing. then you should edit the sheet setup for the foundation sheet to show those classes and layers that you just changed as full and not as grayed. there are a few inconsistencies in the way VWA setup runs, so you may find this in some other sheets as well (such as RCP plans and lighting plans). good luck Quote Link to comment
jdouglas Posted February 16, 2001 Author Share Posted February 16, 2001 Thanks for amazingly fast response. That fixed the problem. Quote Link to comment
