  • 1
Tobias Kern
WISH: New Display Modes for checking
Hi,
besides Vectorworks I am a big Sketchup fan.
Some Display Modes that Sketchup have, are very good
and i like to have in VW too, because you can check
very fast your drawings.
The new Display Modes should be controlled via this menu:
1460644754_Bildschirmfoto2020-10-14um12_00_59.thumb.png.9e3fc9d85b7ff27cd8586e4f247b396e.png
A1.  Color by Axis on/off (see below)
… show all lines in the colors of the axis.
You can easily check if you have cleanly drawn orthogonal.
red = x-axis
green = y-axis
blue = z-axis
black = no x-, or y-, or z-axis
If you set a different axis, the colors should react to the new axis.
1039859635_Bildschirmfoto2020-10-14um11_59_13.thumb.png.ec2f325bc78b14531bdcb9c837acae98.png
A2. Show Endpoints on/off (see above)
… show all endpoint of the geometry.
You can easily check how complex a geometry is.
A3. Show Transparentmode on/off (see below)
… shows the complete drawing transparent
With this mode, you can snap the lines behind.
1739791671_Bildschirmfoto2020-10-14um12_09_47.thumb.png.ce20b6ef16d3e6e3dedb8805f1b8a33a.png
A4. Show Hidden Lines on/off (see below)
… shows the hidden lines of the complete drawing
In this mode, you can snap to the lines behind too.
821214610_Bildschirmfoto2020-10-14um12_09_53.thumb.png.00362a9f4aa329b9af9936c5da1b956f.png
All modes should be mixed together, as you can see in the screenshots.
B.
In VW we can draw in a specific direction via pressing the defined shortcut.
(in the german version we have the "t"-key for that).
This solution is ok and works, but i think the Sketchup solution is way better and faster to manage.
In Sketchup the arrow-keys are defined for the drawing directions.
you click to start a line/polygon, nurbscurve or whatever, then you press
the specific arrow key and then the lines only can be drawn in this direction.
arrow up = z-axis (blue) only up and down
arrow  left = y-axis (green) only forward and backward
arrow right = x-axis (red) only right or left
the arrow down key is a bit special. the key defines a non x/y/z direction,
with the cursor you have to be over a non orthogonal line then press arrow down,
now you only can draw in this direction.
with the other modes (up, left, right) you don't have to be over a line.
Summary:
With this new modes, i think we draw faster and can check more
easily what we have produced.
Cheers from Germany
Tobi
Edited by Tobias Kern
0 answers to this question
