Taproot Posted February 26, 2006 Share Posted February 26, 2006 I just updated with the 2/21 version of the updater for the mac and I'm getting A LOT of issues with the doors and windows. This may be user error, but for the time being, I would exercise restraint when installing the latest update. Issues: Custom window configurations no longer work. Settings are lost as soon as the dialogue box is closed. The door PIO no longer applies breaks to the wall even though they are selected (walls run through the opening). I'll send a test file to bugsubmit. Is anyone else getting these issues? Quote Link to comment
Guest Posted February 27, 2006 Share Posted February 27, 2006 I can't duplicate the problem. Can you provide some more specific information as to the exact problems you are having with custom configurations? When you select the door that is not cutting a wall, what does the top of the Obj Info Palette say? You are encouraged to also send the file along with the description of the problem to tech@nemetschek.net. Quote Link to comment
