LCarm 5 Posted August 10, 2020 Why does the one wall not fit correctly to the object? I have tried different styles and it still leaves a gap. I checked components but I can't figure it out. Thanks for any help 20.07.27 Woodman_1_shed_roof.vwx Quote Share this post Link to post
axhake 35 Posted August 10, 2020 Edit your wall style and change the component settings so that Component Top is is relative to top of wall, also ensure the tick box Follow top of wall peaks is ticked, once done select the wall and from the AEC menu select "Fit walls to Object", select Constraints to top and pick R-Shed Roof, select OK and you should be done 4 Quote Share this post Link to post
axhake 35 Posted August 10, 2020 (edited) Your welcome, you may also consider purging your file as there were a number of unused elements that can be removed to clean the file and reduce its suze. Edited August 10, 2020 by axhake Quote Share this post Link to post
