brian-rwc Posted January 12, 2006 Share Posted January 12, 2006 I was told that VW 12 can import 3D SketchUp models. Could anyone provide more info on this; such as if these models could be exported back into SketchUp. Also, if any of you have used this feature, how well has it worked? - Thank you. Quote Link to comment
rdrines Posted January 13, 2006 Share Posted January 13, 2006 There is a SketchUp plug-in available from the details in this posting: http://techboard.nemetschek.net/ubb/ultimatebb.php?ubb=get_topic;f=12;t=005612 In the work I do with SketchUp here, I use the DWG/DXF file export from SketchUp, and if I want to put something into SketchUp I use the same DWG/DXF file Export/Import method from VW. VW's SketchUp plug-in might make this easier so give it a spin. Quote Link to comment
