AlHanson Posted April 17, 2020 Share Posted April 17, 2020 I'm using the Get Record Node to pull information from Spotlight Lighting Fixtures, and I'm getting everything I try just fine with the exception of Instrument Type which just returns a blank string. Anybody know what would cause this? Image and test file attached. MarionetteLightRecords.vwx Quote Link to comment
Pat Stanford Posted April 17, 2020 Share Posted April 17, 2020 Maybe because the actual field name is 'Inst Type' and you are looking for a field called 'Instrument Type'? ;-) Change your String input to Inst Type and you should be good. Quote Link to comment
AlHanson Posted April 17, 2020 Author Share Posted April 17, 2020 Bah, of course it's that easy. Too busy staring at the field names on the fixtures and not thinking about what the record name is actually using. At least it a simple fix. Thanks! Quote Link to comment
