Yosef Posted March 31, 2020 Share Posted March 31, 2020 I am hoping someone can assist me. I have Vectorworks 2020 on my macbook pro with a file which was created on a windows computer using vectorworks 2019. I am using sheet and design layers. I have rendered the design layer but when I go to the viewport all rendering options are disabled and greyed out in the view tab. I need to export the file to a pdf with the rendered colour and texture but it is now just in b&w. Does anyone know how that can be resolved? Quote Link to comment
Andy Broomell Posted March 31, 2020 Share Posted March 31, 2020 With viewports you don't control the render properties with the View menu. Instead, select the viewport and in the Object Info Palette find the "Background Render" dropdown and set it there. This is because each viewport can have its own render settings. What render mode are you using? You may also have to click the "Background Render Settings" button to further determine the settings you want. For example, with OpenGL this is where you can turn color and textures on or off. Let us know if this helps or if you have any other questions 🙂 Quote Link to comment
