poesy Posted September 27, 2005 Share Posted September 27, 2005 I reconfigured a window symbol and created a new symbol from it. When I try to insert it, it doesn't snap to wall. Instead, whenever I mouse-over the wall with the window symbol, it places itself in a right angle to the wall. So far I have been placing the window symbol near a wall and nudging it into the wall. When I select the symbol, the object info doesn't indicate that it is a symbol in wall. Just wondering what I have done wrong. Is there a better way to do this? Quote Link to comment
CipesDesign Posted September 27, 2005 Share Posted September 27, 2005 So you created a symbol from a window? Was the window inserted in the wall when you ran the "create symbol" command? If so it should work fine (at least it worked for me). Quote Link to comment
poesy Posted September 27, 2005 Author Share Posted September 27, 2005 My window symbol is being quite disobedient.. but I have been using them by first placing them by the wall then nudging them in.. which means during a 3D view, the windows look like they are buried in the wall.. I don't understand.. Quote Link to comment
poesy Posted September 27, 2005 Author Share Posted September 27, 2005 OK I changed the rotate field to 0 degrees in Obj Info. Somehow it was at 90 degrees, that was why it always snap to wall on right angles.. Quote Link to comment
