Hunter B Posted September 9, 2005 Share Posted September 9, 2005 Ok... I've posted this(sort of) before. I am opening 10.5 docs in to 11.2 and get a error almost everytime I use a menu generated custom selection command. Is anybody else having this trouble??? Quote Link to comment
Guest Posted September 9, 2005 Share Posted September 9, 2005 Hunter, I've never run into this problem. Can you send a file you are having this problem with to tech@nemetschek.net with a description of the problem, please? Can you include which custom selection method you are using along with the criteria desired, too? Thanks! Quote Link to comment
